20 Most Recent
Maytag Trash Compactor Motor Switch - 780164 Questions & Answers
Trash Compactor Switch Repair p/n 780164 or777971
Before buying the replacement switch for $80-$100 try fixing it. I've done it and it took only 5 minutes. If you have the skills to replace the switch then you have the skills to fix it. The switch itself is very simple inside and probably costs about $3 to manufacture. Remove the switch from the compactor and disconnect all the wires. Instead of throwing it in the trash, open the switch by pulling the top half of the plastic shell off. You may need to use a small screwdriver to help with that. Once open note the position of the two contact sets. Snap a picture to help you remember how they are oriented if you like but it will only go back together one way. Remove one set of contacts and note the charred contact points. GENTLY, use a small, fine file or a piece of emery cloth to burnish the contacts so that they are smooth and bright. Be gentle! They don't have to look perfect just smooth enough to make good contact. Put the contacts back in the shell and repeat the process for the other set. Put the shell top back on and secure with a piece of tape. Reinstall the switch and reconnect the wires and you'll be good to go!In the time it would take you to order a new switch you can fix the one you have and save yourself a hundred bucks on a grossly overpriced part.
Maplin N20FR - damp test meter. I have no
N20FR - Used to measure the moisture level in sawn timber (also cardboard, paper) 6 to 44% on the left hand scale and hardened materials (plaster, concrete and mortar) 0.2 to 2.0% on the right hand scale
4/14/2024 9:12:34 PM •
Kitchen...
Answered
on Apr 14, 2024
Paragon spin magic 5qr, when spinning causes bowl to shift.
Athletes often talk about the need to find "the zone." This is a state where everything seems to come together and they are able to achieve feats they never thought possible. For bowlers, this zone is often referred to as "the spin zone." When bowlers are able to get their bowling ball to rotate quickly on the lane, they can cause the ball to move in unexpected ways.
2/8/2024 2:23:46 PM •
Kitchen...
Answered
on Feb 08, 2024
Gett motor out of toledo meat slicer
Removing the motor from a Toledo meat slicer involves several steps. First, unplug the slicer to ensure safety. Locate the motor, typically positioned near the base. Depending on the model, you may need to remove a cover or access panel to reveal the motor. Disconnect any electrical connections, such as wires or cables, linked to the motor. Next, loosen and remove any securing bolts or screws holding the motor in place. Carefully lift the motor out of its housing, ensuring that no other components are obstructing its removal. Exercise caution and refer to the specific user manual for your Toledo meat slicer model for precise instructions.
2/3/2024 5:14:04 AM •
Kitchen...
Answered
on Feb 03, 2024
