20 Most Recent
Boss BR1200CD Digital Recording Studio (with ) Questions & Answers
Best sound for dsl15h and MT-2
To achieve a tone similar to Synyster Gates' A7X sound, you may want to start with the following settings:
Green channel:
- Bass: 5-7
- Mid: 2-4
- Treble: 5-7
- Presence: 5-7
- Gain: 7-8
Red channel:
- Bass: 3-5
- Mid: 3-5
- Treble: 5-7
- Presence: 5-7
- Gain: 8-10
When using the Boss MT-2 pedal, set the tone control to around 12 o'clock and the level to taste. This should give you a good starting point for a heavy metal tone.
It's important to note that these settings are just a starting point, and you may need to tweak them to suit your own personal taste, playing style and the room you're playing in.
Keep in mind that the MX112 cab will also affect the sound,so you may need to play with the eq settings on the head and the pedal to achieve the sound you are looking for.
Also, keep in mind that the sound of the DSL15H head with the MX112 cab will be different than the sound that Synyster Gates gets with his rig. However, the settings above should help you achieve a similar overall tone.
1/29/2023 4:52:24 AM •
Boss Music
Answered
on Jan 29, 2023
MG50CFX. Why is fx loop almost silent?
Loaded with a custom 12" speaker, the MG50CFX delivers that iconic ... Take control of your tone with a range of digital FX and four footswitchable channels. ... also has a dual function headphone socket for silent practice or silent recording. ... Effects. Reverb, Phaser, Flanger, Delay, Chorus. Effects loop.
for more visit
https://travismoviereviews.blogspot.com/2021/04/in-earth.html
5/2/2021 6:15:28 AM •
Boss Music
Answered
on May 02, 2021
BOSS ME 70
A multi-effects unit that's as easy as a stompbox - that's the beauty of the new ME-70. The friendly, knob-laden design makes tone creation a snap, but with a powerful COSM AMP section derived from the GT-10, the ME-70 takes the "EZ effects" concept to new heights.
5/22/2020 1:57:47 PM •
Boss Music
Answered
on May 22, 2020
Replace battery in Boss bup2 controller
1. First remove the backplate from the BUP2 by undoing the two small screws at the base of the unit and lift out from the bottom so that the two lugs at the top disengage from their positions. 2. Prior to installing onto the backplate, insert the battery into the battery tray and ensure that positive + and negative - are correctly installed. The battery is a non-rechargeable lithium cell and in the event of power failure will protect your programme instructions for up to 365 continuous days of power loss. 3. The BUP2 is factory set to provide 2 on/off switching periods per day and each day will be the same, i.e. daily operation. To select the other styles of switching you will have to alter the dip switches which are to be found at the bottom rear of the unit into the relevant position for the style of operation you require.
2/11/2020 6:09:22 PM •
Boss Music
Answered
on Feb 11, 2020
