20 Most Recent Fishman Rare Earth Single Coil Acoustic Guitar Sound Hole Pickup (with ) Questions & Answers
Hello, I bought a second hand Martin J1 that has a fishman rare earth single coil pickup fitted. The problem is, when its plugged into the amp ( AER 60w) it makes a cracking noise every so often when
You have several options: 1. Do nothing and live with the occasional problem. 2. Check your guitar cable and the battery connections for loose or intermittent connections/noise. Try to see if it's the amp responsible for the noise....ie, Is it caused by vibrations, or maybe static....especially in winter when it's dry. Your home power may have noise on the line, so borrow or rent a power conditioner which filters out noise. If that fails, go to 3. 3. Bite the bullet and pay a competent guitar tech/luthier to repair it. Most of these issues are due to loose/faulty connections. Should be less than an hour. Hey....It's a Martin. 3a. Pay a guitar tech to loosen the end pin connector so you can see if you can repair it yourself.
12/27/2017 12:28:10 AM • Fishman Rare... • Answered on Dec 27, 2017
2answers
Crackling through amp occasionally
There are only a few things that could be responsible for your problem. Dirty volume knob on guitar or amp. Faulty ground on all affected parts; including cables. I suggest you plug into a different amp with a new chord, and see if the problem still exists. This way you can quickly eliminate compnents & focus on the actua lproblematic one. If it still exists..you can assume it'sin the pick-up.
1/19/2013 12:54:12 PM • Fishman Rare... • Answered on Jan 19, 2013
I have a fishman presys plus on board pre amp. it was working then suddenly no sound is coming out. The tuner is working fine. when i plug my guitar chord, the led light indicator blips one, which is
This is an indication of an internal component failure. The unit needs to be sent in for service. It requires special tools and skill to service.
2/3/2019 1:28:47 AM • Fishman Music • Answered on Feb 03, 2019
Plugging in KPC10M to Fishman amp.
We will need the model of the Fishman you're using to advise you.
7/11/2018 9:26:48 PM • Fishman Music • Answered on Jul 11, 2018
2answers
My Fishman Prefix plus is not working through an
Check the battery in the preamp. Also adjust the eq to see if you might be clipping the frequency you are generating.
ALSO do not overdrive a tuner... they get confused and won't register.
12/23/2017 12:34:08 PM • Fishman Music • Answered on Dec 23, 2017
My fishman clearwave 60 tuner will not give me a green light...it just jumps back and forth between sharp and flat, no matter how small the movement on the guitar key
You may have the tuner too far away from the guitar or the batteries may be going flat. Check to make sure that there is nothing blocking the microphone hole and that there is no other noises in the area which could be affecting what the tuner is hearing
12/15/2017 10:14:58 PM • Fishman Music • Answered on Dec 15, 2017
I have a fishman classic 4t that the battery isn't making a connection, what can I do? Do I need to replace it in my guitar?
can you tell if there is a wire broken? if you know how to use a vom meter you can check to see if you have continuity if you don't then you have a wire problem & make sure that your battery is good.
7/20/2017 2:44:52 AM • Fishman Music • Answered on Jul 20, 2017
0answers
Fishman Rare Earth Single Coil Acoustic Guitar Sound Hole Pickup (with ) Logo
3 questions posted
Top Fishman Music Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Fishman Music Expert? Answer questions, earn points and help others
View Most Popular
Fishman Music
  • Fishman Music
Most Popular Question
crackling amp occasionally
  • Music
