20 Most Recent
JVC VDW14DU Single Unit 2x DVD-RW Storage Media Questions & Answers
I want to recover my Sony Handycam data.
Yes, you can recover data from Sony Handycam1. Do not save any new file to Sony Handycam.2. Remove memory card from Sony Handycam and connect the memory card to computer with a card reader. You should see memory card shown as a drive letter (like H:) in My Computer.3. Download a
file recovery software, recommended asoftech data recovery (simply because i was using it and it worked)
http://www.asoftech.com/adr/4. Install and open asoftech data recovery program, select your memory drive, and click 'Next' button to start scanning process which will find your files.
I put new disc in
change with other if other woking ok then problem card other wise related cam corder
How can i use disc on computer
First off, you need to have a DVD R/W drive in order to use the disc in the picture. If you don't have one, you can purchase an external drive and install it onto your system. From that point, using the disc on your computer I take it to mean how can you BURN a DVD? This depends on your operating system and what program you use to burn it with. There are too many to list here, I suggest using a search engine and asking how to burn DVD's with my ??? system.
Disc Read Error Sony DVD Handycam
Does your camera have other outputs, i.e., composite-video and L/R audio ?
If the disk "plays" inside your video-camera, then use a "video-capture" USB device, to "play" the movie into the USB device, and "record" from the USB device into your computer.
I am just throwing these out there as food for thought.
Make sure you ended the recording on that other side. If a DVD is left open(meaning more could be written to it) other dvd players have a hard time reading the info. Put in one of the 2 sided disc's that worked. how does the camera recognize the disc? Then insert the troubled disc and see if the disc info is being read the same. i.e. disk size, manufactuer, open/closed?
Check for a firmware upgrade for your DVD burner/player(s).
Let me know how things work out.
Tim
Jvc dest error
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjVzpnFyaODAxUYv4kEHcOyC04QtwJ6BAgUEAI&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D2EbPEEclHis&usg=AOvVaw1Zth2un-5jaZpTtXK46KU_&opi=89978449
How tosave image to my facebook
Allyou need is to check on your home page to save the images/photographs in the right hand side. Click and open the page, then open and browse from your picture folder or file , click and upload.All you need is to just follow the window logically and upload the image to the facebook list. you can reset the privacy accordingly for private or public viewing.
