The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.A single signal (LED flashes and beeps once) response from the lock indicates valid entry.A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.Changing the Master Code(Code length: 1 to 10 digit code) Always perform this operation with the door open.1. Enter: # - Existing Master Code - #2. The set light will stay orange for ten (10) seconds.3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.Test the new code several times before closing the door: Enter: * - Code - #• The lock will indicate a valid code change with a single signal.• The lock will indicate an invalid code change with a double signal and the old code is still valid.Changing the Manager Code(Code length: 1 to 10 digit code) Always perform this operation with the door open.1. Enter: # - Master Code or Manager Code - #2. The set light will stay orange for ten (10) seconds.3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.Test the new code several times before closing the door: Enter: * - Code - #• The lock will indicate a valid code change with a single signal.• The lock will indicate an invalid code change with a double signal and the old code is still valid.Activate user codes(Code length: 1 to 10 digit code) Always perform this operation with the door open.1. Enter: # - Master Code or Manager Code - #2. The set light will stay orange for ten (10) seconds.3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.• The lock will indicate a valid code entry with a single signal.• The lock will indicate an invalid code entry with a double signal and the old code is still valid.Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).Changing the user codeAlways perform this operation with the door open1. Enter: # - User Code - #2. The set light will stay orange for ten (10) seconds.3. Enter: New User Code - # - New User Code - #, before the orange light disappears.If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.Test the new code several times before closing the door: Enter: * - Code - #• The lock will indicate a valid code change with a single signal.• The lock will indicate an invalid code change with a double signal and the old code is still valid.The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.Deleting user codesAlways perform this operation with the door open.1. Enter: # - Master Code or Manager Code - #2. The set light will stay orange for ten (10) seconds.3. Enter: User ID Number (3-7) - * - # - #Programming your lock codes2
wikiHow
https://www.wikihow.com > ... > Lock Picking
Grasp the handle and wiggle the magnet until the safe opens. Hold the magnet at the top left corner with one hand and the safe's handle with the other. Slide ...
Volume (in³): 2160 cubic inches
If you want to measure the cubic inches of a container, measure the length, width, and depth in inches. Then multiply those numbers by each other. For example, if your container is 5 inches long, 3.5 inches wide, and 7 inches deep, your calculation will look this: 5 x 3.5 x 7 = 122.5 cubic inches.
May 17, 2023
Cubic Inch Calculator
https://www.homedit.com/calculators/cubic-inch-calculator/#:~:text=If%20you%20want%20to%20measure,x%207%20%3D%20122.5%20cubic%20inches
Sentry Valueguard 1330 Safe Perfect for a home closet, office, etc... Outside dimensions: 22"x17"x17" Inside Dimensions: 14-3/4" deep 12" wide 15-1/4" tall Pic with water bottle is for size reference...
What you have is one of there products. You need to go to the following web address they have an on line form you fill out and will provide u with an opening combination.
https://www.sentrysafe.com/support/
You just buy another one, they are 50 bucks new.
Or contact Sentry Safe and see if they will sell you one.
Or take it to a locksmith and they will order and fit one for 75 bucks.
You are pretty stuck with that scenario. With an electronic lock you can use a rare earth magnet to pull the locking bolt but with a manual dial safe, you can't do that. I can remember my business safe combination from 1987 to 2005. You can also write it down.
Use a concrete saw or angle grinder and cut the back off it.
Question edited for clarity.
Although this guy makes it look hard work, they will usually bounce open quicker that this. You can also bang the top with a rubber mallet, or use a rare earth puck magnet to pull the actuator bolt.
If your Sentry Supreme 5330 safe is not opening, there could be a few possible reasons why:
Combination Error: If you are using a combination to open the safe, make sure that you are entering the correct combination. If you have forgotten the combination, you will need to contact Sentry Safe customer service to get assistance on how to recover or reset your combination.
Dead Batteries: If you have an electronic lock on your safe, the batteries may be dead. Replace the batteries and try again.
Jammed Bolts: The locking bolts may be jammed due to incorrect operation or a mechanical problem. Try tapping the safe door gently with a rubber mallet to loosen the bolts and then try to open it.
Mechanical Malfunction: If the safe still does not open, there may be a mechanical malfunction. In this case, you will need to contact a professional safe technician to diagnose and repair the problem.
Note: If you have lost your key, you will need to contact Sentry Safe customer service to order a replacement key.
The sound does two things
It lets you know you have done a positive button push.
It beeps when the battery is low to alert you to change them and save you having to cut the back off the safe.
It isn't programmable, snip the wire to the sounder, but it is likely hard soldered to the main board.
