20 Most Recent Lexar 64MB FLASH MEMORY DRIVE USB 2.0 - (JDCL064231) Hard Drive Questions & Answers
Just plug it in. If it's not recognized, you may have to format it in a computer to FAT32. Make sure you back up any data on it before you reformat it.
Lexar 64MB FLASH... | Answered on Jun 19, 2014
You have to be the computers administrator to change any values on any hard drive on your computer. Click start control panel user accounts on the users tab click the name of the computer administrator you must have full control Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP Click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Click start click on my computer you should see your usb drive right click then select format another way is to control panel administrative tools computer management disk management right click on your drive select format
If you need more help with this post a reply
Lexar 64MB FLASH... | Answered on Mar 11, 2013
you will need to connect your lexar to your computer
click start click on my computer to open from there you should see your lexar then right click to select open you should see
the data / photo's in there select what you want to delete right click select delete or you can right click select format this will delete all data on hard disk
hope this helps
Lexar 64MB FLASH... | Answered on Oct 05, 2012
The device has "died". Spend $8 to buy a new 2048 MB (32 times larger) flash-drive.
Lexar 64MB FLASH... | Answered on Dec 30, 2010
if your system makes a connection with the device on plugin , you should here a dual toned sound indicating its been plugged in and recognised. if you here this and still dont get a popup. the device can be found by opening my computer link in start menu and then selecting the removable or flash drive icon usually listed last in the letter labels. c: being your main hard drive and so on.
Lexar 64MB FLASH... | Answered on Nov 29, 2010
if you have moved everything off it, just right click and choose format.
You can do this from my computer, or disc managment (right click my computer/manage/disc managment)
Lexar 64MB FLASH... | Answered on Jul 10, 2010
hello! you can plug it into your computer's usb port. its rectangle lookin jack somewhere around your power button. just push it into it.
Lexar 64MB FLASH... | Answered on Jun 30, 2010
To save a web page in Internet Explorer, go to that page and click File, then "Save As." In the box that pops up, use the My Computer link on the left to navigate to where your jump drive is, or click the down arrow next to the current folder at the top of the box. Once you've gotten to your jump drive and selected it, click the drop down box next to "Save as type" at the bottom of the box and choose "Webpage, complete." Then click Save.
To save a web page in Firefox, go to the page you want to save, and under the File menu, choose "Save Page As." When the dialog box comes up, click My Computer on the left, or click the arrow at the top next to the current folder, and navigate to your jump drive. "Web page, complete" should be the default selection for "Save as type" -- if it's not, select it from the drop down box. Then click Save.
Web pages typically save as many files within a folder, so if you accidentally delete or move any of those files, reloading the web page might not work.
Lexar 64MB FLASH... | Answered on Jun 10, 2010
the problem is the Operating System is trying to assign the flash drive a drive-letter that is already assigned. For example it is trying to assign the drive-letter "D" which is already your cd drive. If you right click on the "My Computer" icon and select "Manage" then select "Disk Managment" you can change the assigned drive letter of the flash drive to a un used drive letter. Once you do this the Operating System should be able to see and use the flash drive.
Lexar 64MB FLASH... | Answered on Jan 26, 2010
click My Computer, click right button your mouse on the flash drive, click property
Lexar 64MB FLASH... | Answered on Oct 20, 2009
>lets open windows address book
>Export the contacts>as Address book (wab)>save it on to desktop and give a file name
>Once it is saved copy and paste it to flash drive
>lets connect the flash drive to another computer
>lets copy the file and paste it to desktop
>lets import the file from desktop
Lexar 64MB FLASH... | Answered on Aug 29, 2009
Go to my computer and open it, and you should see the Flash Drive. Right click on it, and from the dropdown menu select format. (It will be FAT 32)
As I am not familiar with your exact make of drive, check that if it has a tiny slide protect switch on the side. If it has, try formatting it, if it won't, push the switch forward or back and it should then format.
As you do not give details of your computer, I cannot give further instruction for a your Operating system.If it's XP the drive should be recognised automatically, but if its Win98, it will need you to install the driver you got with it on the CD supplied..
Lexar 64MB FLASH... | Answered on Aug 27, 2009
It sounds like your media is malfunctioning (electronics).
For this type of problem, we offer a data recovery service.
You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Lexar with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
ericb@lc-tech.com
1-866-603-2195 ext 103
LC Technology International
Lexar 64MB FLASH... | Answered on Jun 25, 2009
I think there is a virus that has disabled your pen drive please follow these steps to try and remove that disability for the pen drive.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate, and then click the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\UsbStor
4. In the right pane, double-click Start.
5. In the Value data box, type 3, click Hexadecimal (if it is not already selected), and then click OK.
6. Quit Registry Editor.
Hope you like my solution.
Lexar 64MB FLASH... | Answered on May 25, 2009
1- Unhide Files and Folders in Tolls Menu
2- You will find Autorun file in your Existing Drive. Just Rename or Delete that file.
3- Reboot Your PC
Thats all
-Rajkumar
Lexar 64MB FLASH... | Answered on May 19, 2009
2- You will find Autorun file in your Drive. Just Rename or Delete that file.
3- Reboot Your PC
Thats all
-Rajkumar
This device should be plugged into any computer that has USB ports to plug into. Usually, you plug it in and you will see something pop up in the bottom right corner of the screen about installing usb drive. When it is done installing (usually takes about 1 minute), you can open My Computer and see it in there as a removable drive. Open it and save your files directly in there by copy and paste or drag and drop.
Thanks,
Lolita
Lexar 64MB FLASH... | Answered on Mar 18, 2009
Lexar 64MB FLASH MEMORY DRIVE USB 2.0 - (JDCL064231) Hard Drive Logo
Popular Tags
50 questions posted
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
gggg
Dayton Computer
Dayton Computer
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lexar Computers & Internet
Most Popular Question
want delete old photos from lexar
  • Computers & Internet
