20 Most Recent Lowrance HDS-8 Questions & Answers
Try this link:
http://support.lowrance.com/system/selfservice.controller?CONFIGURATION=1001&PARTITION_ID=1&secureFlag=false&TIMEZONE_OFFSET=&CMD=VIEW_ARTICLE&ARTICLE_ID=2874
Lowrance HDS-8 | Answered on Nov 15, 2014
its hard to describe a school of bait fish on the screen less you know what your looking at you need to go on line to www.lowrance and go to there what bait fish looks like on your screen page it will show you all you need to know and how to set your unit to know what your looking at and how to read your screen on your unit
Lowrance HDS-8 | Answered on Dec 19, 2013
Make sure the transducer is pointing directly down when the boat is in the water. Also, this may help
Lowrance Boating | Answered on Jul 03, 2019
Need to contact the manufacturer for support on this. It may not be fixable.
Lowrance Boating | Answered on Jun 10, 2019
Probably time for a new one. Harsh conditions like on a boat causes the electronics to fail after awhile
Lowrance Boating | Answered on Jun 05, 2019
Check the Positive and negitive terminals It may not be seeing the voltage it needs , I have a strike 7 and it did a similar thing , as soon as the load from the transducer is on it wont load ,, Mine was the dirty Neg cable to the bus bar under the dash
Lowrance Boating | Answered on Apr 24, 2019
To many possibilities. Low voltage, problem with hydraulic pump, no voltage on hydraulic pump, broken wire, heading sensor etc
Lowrance Boating | Answered on Feb 02, 2019
Loss of depth reading over 15kph, is usually caused by either turbulence from under the chines of the boat, or that the transducer is toe up, or back end up. If the transducer throws up spray, it is back end up. Toe up is harder to see. Get someone to drive the boat and look overboard. The transducer needs to be flat at the speed you want to see the information, and of course that changes depending it you are trolling or on plane and your trim.
Not marking fish could be a faulty transducer or that the sensitivity setting is not set high enough. Read the manual. I am a Humminbird person :>)
Lowrance Boating | Answered on Dec 30, 2018
Lowrance HDS-8 Logo
8 questions posted
Top Lowrance Boating Experts
Bob Peloquin
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
View Most Popular
Lowrance Boating
  • Lowrance Boating
Most Popular Question
hard start hds 8 did soft start did not
  • Boating
