20 Most Recent
Tomtom Go 700 Portable GPS Receiver Questions & Answers
I purchased a used sd card western Europa. di i need to activate it and how can i update it
If you insert the SD card into your TomTom device, and you can see it ... as one of the maps on your device ( when you go to Menu ... Change Map ... etc. ). ... try selecting that map, and if it doesn't tell you it is not available or not activated, then you can use it. Otherwise, you need an activation code to activate the map.
If the map on the SD card is a LifeTime map, you can simply connect your device to the tomtom website (using the HOME software), and it will let you know you have an update (of that map) to download and install. Otherwise, you have to subscribe (i.e. pay) for an update of the map.
1- somtimes disaprears the road
sounds like the maps are out of date and do not show recent developments. You may be able to update with shared info on the internet
When turned on, screen has picture of unit with
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Tomtom Navigation in German Need English
Tap "Change language" button to change the language
You can choose from a wide range of languages. When you change the language,
you are also given the opportunity to change the voice.
you can download manual
go to tomtom website ----> support scroll down at the right hand side click Find downloads
20/Apr/09
Tomtom go 720 problem
There is a limitation for how long demo route the unit will show you, and I think you found it, Demo Blemo...
Problem
It freezes as soon as it turns on. You can only turn it off by the reset button.
Tom Tom Gps One
Tap screen, then tap lower middle icon, tap Right Arrow seven times, tap button with country flags, choose your language...
Screen not working-Power light on
Possible back light failure.
don't know about 'repair for this sort of thing
Mu guess is like other small electronics of this type they are made as integrated 'lumps' and there is not a repair option.
Try the Tech support at the TT website
Especially if it is fairly recent.
May be a replacement option
Tom tom go 60/61 maps
Did you run out of memory? Just it have an SDHC slot? If so install a 16GB card. Try again.
Why tomtom seems I changed the battery it's not working
The screen shows an X when the navigation software on your TomTom is corrupted ... and it will not start (boot) up the device.
Have you tried contacting TomTom Support, to have them walk you through this problem ? assuming you recently bought your TomTom and it is still on warranty.
How to update tomtom go 4cq02
do a google search for tomtom then connect it to your computer after installing tomtom home and it should automatically update, you will firstly need to set up an account with tomtom though. (free i think)
