20 Most Recent Network Computing Devices (NSH800S/A) Networking Switch Questions & Answers
2answers
My downloaded songs, sound horrible
It is possible that your eq settings have changed try resetting them
6/2/2017 4:57:37 AM • Network... • Answered on Jun 02, 2017
Why only 254 computers are connected in one
If we use class c network (192.168.x.x) we can connect devices up to 254 because in class c network first three are network positions. last one is host position. (network posotions 192.168.x host postion is x last one) In class B network mean 172.16.100 we can connect more than 254 because in this network ips are 1-254 after 254 hundred we can change to 101.
Note: In class B network 2 network and 2 host positions. network positions are fixed. Host positions are changeable. so we can change. like that class a one network position and 3 host positions. (ex: 10.0.0.0 in that 10 is fixed. remaining we can give as we like) but we cannot give 256 ip address to any client. because that calculations support up to 254 only
6/23/2015 11:13:53 AM • Network... • Answered on Jun 23, 2015
How do I connect my Netgear DGND3700 router to Fibre internet (BT infinity)
Hi there Your Netgear router will not connect to BT Infinity directly as the built-in modem is ADSL/ADSL2+ and Fibre requires a VDSL modem as in the HomeHub5 or the BT Openreach modem. Either of these can be used with your Netgear as a subsidiary router/access point. You may now be able to get a router with a VDSL modem built in but 3 years ago it was really only available from BT and BT did not support other makes. Hope this clarifies matters though perhaps not too helpful
11/8/2014 5:59:00 PM • Network... • Answered on Nov 08, 2014
0answers
Hi, As a Programmer. While writing the codes I
Just go to www.onlinedocumentconversion.comregister & buy some credits thenconvert your file easily into doc format. If you have any difficulty, contacttheir 'After Sales Support & Service' team - they are a bunch of friendlyand helpful folks & I am sure you will like taking their help.
3/7/2011 11:33:51 AM • Network... • Answered on Mar 07, 2011
tip
Set up a home office LAN which access internet through USB wireless gadget
The following networking job I have done in this Lab. It is enough for a small office to access or transfer file Printing and access of shared Internet in different type of operating system.
We have recently set up a home office (small laboratory) LAN. All the computers access the internet through a USB wireless (CMDA) dongle. The USB stick is Huawei EC168C and internet service provider is Reliance Infocom (India). But any USB internet dongle can be use to share internet in a LAN in the following way. And you don't need a router for that. In the areas where ISP cannot give wire line internet connection this type of USB wireless sticks are really helpful for home office.
Basic LAN Connection:
Here this lab has 4 PCs. One Windows XP, another Windows Vista starter and two RedHat Linux server systems. Here in this lab I have done the basic LAN connection using cat5 cable & RJ45 connector and an 8 port hub. I have connect the two windows based OS. Using cross cable I have connected two windows system with the hub. Then I put static IP address in Ipv4 of TCP/IP. After that I set workgroup name to join in a workgroup in windows PCs. Then I tried to ping the systems, and it was pinging. Then I have setup a home or small office network in both windows system. That I have enabled the Printer sharing. After that I can share file, data and printer through the system gateway.
Now I have to connect other two Linux PCs in this network. With same cross cable I have joined the both Linux system with the hub. Then to detect the Ethernet device I have put down "DEVICE=eth0" entry in /etc/sysconfig/network-scripts/ifcfg-eth0 file. Then I set IP address in Ethernet device in network configuration in graphical mode (or System-config-network in text mode).After doing this job I restart the network service with "service network restart" command. Then I am trying to ping the systems to one another, And It was pinging.
Now Linux system can access with each other and files also shared through SSH, Telnet,FTP using process and command.
Linux Configuration:
I have configured the Linux system in the following way. First I have set the host name in /etc/sysconfig/network file by VI editor. Next I have edit /etc/sysconfig/network-scripts/ifcfg-eth0 file with "Device=eth0" to detect the Ethernet device. After that I have put the IP add in network configuration file and Restart the network service. To keep the eth0 on permanently I also use the chkconfig command.
After doing this job File sharing can be possible through network file sharing (Nfs). I have install Nfs package & shared the nfs dir by editing exports file. Then I am trying to automount the NFS dir by automounting process. So that I put automounting entry of nfs file in fstab file. After that it's automounted in other system's mount location.
Windows & Linux Networking:
Through basic LAN both OS can only ping each other. To share file or data samba server (a client server in Linux) must be configured in Linux system. So I Install smb rpm package from yum repository. Then I have Configure the samba/smb.conf file. I put the Workgroup name on Workgroup column of samba/smb.conf file. Then I Set the network IP without host to route in network in Host allow column. At last I put down all details of Samba dir, users at the end of the configuration file set the samba password. After that I restart the samba demon to up the samba server. Now files can shared through samba server. In windows I Set the workgroup name pairs with samba server and also set username and password same as samba server. Now I trying to send or access file through samba in both OS and it happened.
USB Net Connect:
Here in this lab workers are use internet from an Usb net connect. So it must be shared in Network. It is too fast so shared internet can be access easily. In Windows XP system I connect the USB netconnect & share it in network. IF all the network setting is ok then all the systems can access shared internet through gateway. Here all users use this shared internet now.
Access of Another System: VNC Server & Viewer is software through which we can access of another system easily. I just install the software & set the password. Then I run the vnc server. After that I Put the IP add of vncserver from vncviewer of another system and type the password & start access the vnc server system. It can be access form WAN also. I just Run the Vnc server and connect the internet and I got a Wan IP add provided by ISP.
0answers
I got a msg from
Be the first to answer 1/12/2011 3:09:00 PM • Network... • Posted on Jan 12, 2011Be the first to answer
0answers
I got a msg from
I got a message from hire info regarding my offer letter but i could not found please send the offer letter my e-mail my mail is [email protected]
1/12/2011 6:04:41 AM • Network... • Answered on Jan 12, 2011
I got msg from BL-hrinfo,
ITS IS AS I THINK FAKE SMS SERVICE..BIJAN ROY. I ALSO GOT A SMS .BUT CANNT FIND ANY LETTER IN MY MAIL ID
12/31/2010 7:13:24 AM • Network... • Answered on Dec 31, 2010
How can i convert videos so that i can see them on
I'm not sure what media files does your MP3 player support.But still 3gp,avi,mp4,amv are the most commondly supported media files by Mp3 players.
I recommended to use xillisoft video converter ultimate or iskysoft video converter as they are very compatble with mobiles medias plus high quality.
Xillisoft video converter ultimate
http://rapidshare.com/files/149900954/Xilisoft.Video.Converter.Ultimate.v5.2.7.Incl.KeyGen-tRUE.rar
Iskysoft video converter
http://rapidshare.com/files/247351795/iSkysoftVideoConverterv2.1.0.51.rar
Both this software can be used to convert videos to mp3 too.
12/14/2010 2:54:57 AM • Network... • Answered on Dec 14, 2010
Sir, please send
received massage : tata limited: your resume has been selected. Your letter already sent your Email.
11/30/2010 5:00:25 AM • Network... • Answered on Nov 30, 2010
Drivers on RICOH support site don't work for my
did you try the drivers on the disk that came with it?
11/22/2010 5:18:11 PM • Network... • Answered on Nov 22, 2010
I am not able to
?? you have posted this in the wrong place.
No one here sent you a letter for any job.
This is a computer help forum
10/8/2010 10:05:26 AM • Network... • Answered on Oct 08, 2010
I have sam for the
Absolutly no idea what it is you are asking, it may be a better idea to ask in your own language, or google translate
10/7/2010 2:52:19 PM • Network... • Answered on Oct 07, 2010
HITACHI LTD.-Your resume selected by
mahesh bobade
10/7/2010 7:58:43 AM • Network... • Answered on Oct 07, 2010
Network Computing Devices (NSH800S/A) Networking Switch Logo
Popular Tags
92 questions posted
Top Network Computing Devices Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Network Computing Devices Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Network Computing Devices Computers & Internet
Most Popular Question
downloaded songs sound horrible
  • Computers & Internet
