20 Most Recent
HTC XV6900 Cell Phone Questions & Answers
How do i get apps
If you have android market icon on your menu,just open the apps and choose weather you want free or paid application,be sure you are connected on the internet using wifi or GPRS network.
My XV6900 cannot connect to
Hello and thank you for your question,
The settings for your phone to properly connect to your cellular provider have seem to have been changed. To get these to the proper settings please contact your cellphone provider so they may fix this for you.
Please remember to rate this answer for your ratings help me better serve you and the community of others like you needing help.
Once again thank you for you for using Fixya.com and for all your technological needs please continue to use fixya.com where you will find the answers that Fixya problems.
Sincerely,
Zachery D.
Fixya.com - Guru: zdeuyo
How do i get my HTC XV6900 unlocked or unflashed
if you are trying to unlock it from the network to use on a different providers network or to use internationally than you need to get the unlock code from the provider that supports that phone. keep in mind if you are going to use it on a diff network than what is was made for it may not work up to its full functionality, especially internet, bc the phone was designed for a specific network and the settings will not be the same.
How to download pictures and videos to a mac
Here is the step-by-step introduction for you:
Step1. Download, install and then launch Video Download Studio from http://www.downloadvideos-convert.com/download-videos-music.
Step2. click” add” button to load your files to Video Download Studio.
Step3. Click “convert” button on the top to switch to convert interface.
Step4.click on the videos, choose them as the conversion file.
Step5. Click the drop-down list to select the mp4 format for each video.
Step6. Click” convert” button at the bottom to begin the conversion. Video Sharer will convert your videos one by one. After the task finished, you can find your videos on the conversion file.
Hello, my HTC touch XV6900
1. Check your battery voltage, you can do this with your tongue, if you feel a salty taste with pricking effect, then there must be no problem with it, but if you are not familiar with this testing, you'll not be able to assume the voltage.2. Please check your battery, if possible, you need to try it using another battery so that you can make sure it's not the culprit.
3. Check your battery connectors and interfaces, you can clean them using an eraser (rubber)
4. Remove everything (like memory card, sim card, etc if any) and switch on using the battery only.
5. If you have the flashing software, you can boot it from there, if you don't you can go and check it from a mobile repairing shop.
6. Verify battery is charging even if the phone is switched off or not.
If all of the above can't fix it, then there's an internal problem, which would be difficult to repair. You only choice is to visit a service center for Htc handsets.
I think there must be a cause, how this started. If you can, please let me know when and how it failed. Good luck.
Thanks for using FixYa.
Forgot password need to reset
I'm afraid you'll have to hard reset your device, in order to get rid of your present condition. You, most probably, know that a hard reset will restore your device to its factory default settings, thus deleting all programs you have installed, as well as your personal data and settings. Hope you have a recent backup, to be used afterwards to restore all your settings. Anyway, to perform a hard reset, press and hold both the green TALK and the red END buttons, and, whilst keeping them pressed, briefly press the reset pin with the stylus pen. Keep pressing the keys until a confirmation request screen comes up. Confirm the procedure by release the keys and pressing the ENTER button.
Hope you are able to sort your problems out.
Regards,
Carlos
Htc 6900 smart phone
- The problem here is that you don't actually have a camera flash on this phone. What you are mistaking for a flash on the back of your phone is a personal reflection mirror so that you can take pics of yourself. Check out the specs here - http://www.shopamerica.htc.com/cell-phones/productdetail.htm?prId=34469
My HTC XV6900 I can't
Well it sounds like the internal speaker has a problem. It may also be ringing funny at times. Unfortunetly there is no easy/cheap way to replace the internal speaker. If you have warrenty you should back everything up you can and take it in.
You can get new cases and other internal parts for this model but I didn't see the mainboard or speaker so your only replacment source maybe from HTC.
http://www.htc.com/us/support/
The board should be about $100 if it were available third party but I don't know htc's charge. They will usually have a flat refurbish or replacment fee that covers all repairs or you get a new phone back.
Touch Screen is not working
Since this is the case you may need to soft reset the phone.
The touch screens normally give problems whenever there is a little pressure applied to its surface e.g when you don't use a pouch but place the phone in a tight jeans pocket and thus will need,screen reallignment.As you may already know.
Now your phone has a soft reset function...try it! Or turn it off,remove the battery (not immediately! so you don't loose your settings then re-insert it after 25 secs.) and do a restart. This should allow you access the screen allignment settings so that you could fix your screen.
Hope this helps.
User manual need
Hello u can download the manual here. Please rate me. Glad i could help you....paste this in your address bar...http://www.phonedog.com/cell-phone-research/htc-touch-xv6900_user-manual.aspx
An error occurs when trying
youtube doesnt work. Do VTAP.com it's free and it's uses youtube. :) It uses youtube in a way that media center can understand )
What is the Telus network unlocking code for an htc phone
Only Telus can unlock it and only if the rent to own contract is paid off. If you take it to a third party unlocker, Telus can still lock it on you by using the IMEI number.I would urge you to edit out your IMEI number as it can allow the unscrupulous to clone your phone and make calls at your expense.
