20 Most Recent
Gaggia Brera Coffee Maker Questions & Answers
GAGGIA Brera RI9833/61 - Descaling light still on after descaling
I think that you button doesn't make a good contact. Try to press it with different pressure and on different sides slightly off center to give this a try - it may be just a bad contact that is enough to change the bean setting but not enough to reset the warning indicator through a long press. Let me know how it goes ... they may have changed the button that needs to be pressed as well (does your manual say anything different?)
Descale alarm
You have to reset this manually after descaling. This is done by pressing the bean selector button for 6 seconds.
When I press the espresso button instead of esspreso makes a long coffe .I must ad I descaled it yesterday .
You may have accidentally changed the amount setting for your espresso shot when resetting the descale counter.If you lost the manual you can find one here.
http://www.gaggia-usa.com/support_docs/Gaggia_Brera_Quickstart_Guide.pdfOn page 11 (with the printed number 31) you find how to change these settings:• Place a cup under the dispensing spout.• Hold the "espresso size" button pressed for 5 seconds to enter the programming mode; the "coffee" icon will blink quickly and the coffee will start to be brewed; the icon will flash during the whole coffee brewing cycle.• Press the same "espresso size" button again when the amount of coffee in the cup reaches the desired level.At this point the button "espresso size" is programmed; each time it is pressed and released, the machine will brew the same amount of coffee that was just programmed.The same operation can be repeated for the "Lungo size" button.
