20 Most Recent
Morphy Richards AM925EF Microwave Oven Questions & Answers
Buzzing noise
follow this instruction and fix it. God bless you
- MagnetronIf your
microwave is emanating high pitched or growling noises during operation,
the magnetron could be going bad. Normally a nearly silent part, the
magnetron uses high voltage and induces the frequency required to cook
food. Although normally not a safety hazard to operate, this is a sign
that the magnetron is failing and will need to be replaced as soon as
possible.
- Exhaust fan motorIf
your microwave is making a very loud humming noise during operation, it
could possibly be the exhaust fan motor. If defective the part will need
to be replaced to silence the appliance once more.
- Stirrer motorAnother
leading cause of a noisy microwave is an expired stirrer motor. With use
this part becomes worn and makes a loud grinding noise, which is
usually a leading indicator that the part needs to be replaced. The
stirrer is a metal blade that is slowly turned by the motor. This action
disperses the microwave energy in a random pattern, which heats the
food evenly. If the stirrer motor is determined to be nearing
expiration, it should be replaced to halt the grinding noise.
- Turntable motorA very
common cause for a noisy microwave is a worn out turntable motor. This
is a relatively easy repair and will put an end to the noise once
replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZYUSVYSH
My problem is i have lost my manual book
Sorry for the delay Margaret, but no instruction manuals for that model are available anywhere online.You are welcome to request a refund of your FixYa service fee, or I can try to help you with any other technical problems you may be having at no additional cost.My aologies once again, and thank you very much for your consideration. I truly hope that we can provide you with better assistance next time.Take care.Joe.
Inside of microwave top peeling and blistering
If it's paint peeling, then once that paint is gone, rust will set in, which can cause arcing and disintegration of the chassis, when ruins the oven.This peeling is usually the result of excess moisture accumulating in the oven due to blocked air vents or poor fan circulation.Once those two issues have been ruled out or dealt with, then always be sure to dry out or leave the microwave open after use.The peeling paint will need to be removed, then the area should be sanded.Then you can apply some
high-temperature appliance paint, available from places like Wal-Mart,
Lowe's or Builder's Square.
We're
happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
Model number AM925EFP. It behaves
Actually there is a part installed in Microwave By the Name of Magnetron get it checked by techinician i do have the best way to resolve it in free of cost but get it checked first its dead or not
