20 Most Recent
Frigidaire FAM157S1A Air Conditioner Questions & Answers
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Thermostat will not cycle compressor temperature
Good Afternoon Friend,
I understand that the thermostat is not cycling the compressor on and off on your Frigidaire air conditioner, model# FAM157S1A. Please check the temperature sensing element to see if it is touching a cold coil. This will be located behind the air filter. Straighten away from the coil if it is touching. The other possibility is the compressor shut-off by changing modes. Wait approximately 3 minutes and listen for compressor to restart when set in the COOL mode. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
FAC107P1A
DRILLED INTO COOLANT LINE WILL NEED TO FIX AND RECHARGE
Why doesn't it have any condensation
Hello, if the unit has a drain it may be blocked and not allowing the water to drain. If no drain is present then the unit uses the condenser fan blade to scoop up the condensate and splash the condenser. This is done for two reasons, to keep the condenser cool and to evaporate the condensate
The temperature gauge has stuck
Turn the unit OFF using the ON/OFF Switch and unplug it for 15 minutes. After the time has elapsed, plug the unit back in and turn the unit ON. With any luck, the electronics reset and reverted back to the original factory settings. You should know immediately, once the unit is turned ON. If they did, you can now set the controls as you like. If they didn't, the control panel will need to be replaced. Parts are available from Frigidaire or their authorized distributor.
Hope this helps and thanks for choosing FixYa.
Accidentally cut the power chord.
get some tape and splice it back to gether. wire nuts would be best .. just make certain your connections are tight and well taped.
