20 Most Recent Kingston Digital 8GB DATATRAVELER C10 (BLUE) s Hard Drive Questions & Answers
Cannot read the content of my pendrive
download and follows instruction
1/13/2014 10:58:18 AM • Kingston Digital... • Answered on Jan 13, 2014
2answers
Kingston datatraveler 8gb was unable to complete the format
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select openRight click the icon of your Usb Drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. click start click on my computer to open you should see your drive right click then select format another way click start control panel administration tools computer management disk management right click on your usb drive select format if you need more help with this post a reply hope this helps you
1/13/2014 10:57:46 AM • Kingston Digital... • Answered on Jan 13, 2014
2answers
How to unprotect the protected usb flash drive
Bruteforce password tools if U dnt know the password.
9/29/2013 2:21:16 AM • Kingston Digital... • Answered on Sep 29, 2013
8GB BLOQUEen enregistrement +pas d'acces
google translated Recording + 8GB BLOQUEen no access W 7 First, please disconnect all USB devices and then perform the following steps: Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK". Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers". Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
1/31/2013 4:55:31 PM • Kingston Digital... • Answered on Jan 31, 2013
The product is not performing
Click start control panel Administrative tools Computer Management Disk Management right click on your drive select properties click tools you should see click check now click start two boxes Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not do anything while the chkdsk utility is in progress any input may damage this drive. You might get best results ticking in one box the returning after it has finished then ticking the other box it might take some time depending on the of your disk but be patient.
1/31/2013 4:52:18 PM • Kingston Digital... • Answered on Jan 31, 2013
Kingston DT101G2/XX USB cant format it
helo
12/2/2012 1:14:07 PM • Kingston Digital... • Answered on Dec 02, 2012
How to format flash drive file system is RAW
click start click on my computer you should see your usb drive right click then select format another way is to control panel administrive tools computer management disk management right click on your drive select format hope this helps
9/6/2012 9:06:04 PM • Kingston Digital... • Answered on Sep 06, 2012
I bought a pink 8
Before return it try with another PC then let we know, or let the seller check it for you: you don't have to pay nothing.
7/9/2011 4:53:33 PM • Kingston Digital... • Answered on Jul 09, 2011
Kingston 8gb pen has malfuntioned
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
5/30/2011 10:22:35 AM • Kingston Digital... • Answered on May 30, 2011
0answers
0answers
0answers
What year was house built on 31 Nolan crescent Kingston tasmania
Approximately 1984
5/12/2017 9:47:32 AM • Kingston... • Answered on May 12, 2017
0answers
0answers
Kingston Digital 8GB DATATRAVELER C10 (BLUE) s Hard Drive Logo
16 questions posted
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Kingston Computers & Internet
Most Popular Question
cannot read content pendrive
  • Computers & Internet
