20 Most Recent Thomson RCA DCM245R Modem Questions & Answers
My modem randomly resets and no internet.
either the modem is going out or its a problem with your internet provider. before calling to complain to the internet provider. run down to your local walmart or electronics store and pickup a modern if you have the same issue its your internet provider. i delt with a modem that was causing a similar issue. the problem ended up being the modem was running hot. i modified the case and added an external fan and the problem went away. hope this helps. good luck iupsnhw-c3jomsvkxq4mzqkwo1v3hab2-5-0.jpg
3/3/2017 5:42:36 PM • Thomson RCA... • Answered on Mar 03, 2017
manual
0answers
0answers
2answers
RCA DCM245R Modem Vista
Hi Ken:That's not my expertise but you could try installing some drivers: rca-thomson-dcm245-driver.htmlHope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.Thank you for using Fixya, and have a nice day.
1/29/2012 6:55:35 PM • Thomson RCA... • Answered on Jan 29, 2012
My modem is: thomson
Do you have a wi-fi password in place on your router?
3/7/2011 8:30:45 PM • Thomson RCA... • Answered on Mar 07, 2011
Comcast is my service provider and I have had an
It can be an issue with the modem or with the line. When the line drops the link then the modem shows only two lights. And, when you power cycle the modem (unplug and replug it) it establish the session again with the comcast.
So, i'll suggest you to get the line checked first and if comcast finds that line is working fine then get the modem replaced.
Rashish
8/15/2010 8:10:40 PM • Thomson RCA... • Answered on Aug 15, 2010
Hi have a thomson spedtouch 530 modem and im
You can download the installation driver directly from here: http://www.driverstart.com/start357341.html
Hope this helps. If so, please rate. Thanks.
4/19/2010 8:28:35 AM • Thomson RCA... • Answered on Apr 19, 2010
All of the lights are blinking in unison
Check to see if there's a reset button on it somewhere, and reset it, if you can. It sounds like a heat problem, since it's been getting worse and worse. Not much you can do in this case except have it repaired, or buy a new one. Get an estimate first, though, often it's better to buy a new one than pay as much or more to fix the broken one.
3/21/2010 8:55:42 PM • Thomson RCA... • Answered on Mar 21, 2010
Need username and pwd
To access the configuration: The default user is 'Administrator' and the password is blank.
Make sure you have your DSL username and password to log into you DSL service. If you don't have it your service provider can give it to you.
If that doesn't work find the reset button on the back. Do not use the front reset. Hold the reset buttion in until the power led flashes red. This should reset the unit back to factory. You will need probably need you DSL username and password to re-configure the router.
3/6/2010 8:33:14 PM • Thomson RCA... • Answered on Mar 06, 2010
How to turn on ethernet?
Your modem should be on when it is plugged in - "always on". If your ethernet light is not on, there is either an issue with your modem, or with your cable internet provider. Please contact their technical support people for appropriate troubleshooting.
Have I resolved your issue? If so, please rate this. ty.
2/26/2010 5:38:20 AM • Thomson RCA... • Answered on Feb 26, 2010
Non connectivity with thomson tg585 v7 modem with bsnl broadband.
what is bsnl broadband if you have thomson to acsess the setup and all it freater just type speedtouch.lan in your browser this may help you
i think
8/30/2009 11:32:48 PM • Thomson RCA... • Answered on Aug 30, 2009
Comcast internet
Yes you can get the internet with that modem but only through a cable connection.
Here is the specs on that particular model for your information >>>>>>>>>>
http://www.newwavecom.com/phone/pdfs/DS_DHG535_200802.pdf
Regards.
7/20/2009 5:32:59 PM • Thomson RCA... • Answered on Jul 20, 2009
2answers
How can i connect an additional pc to my rca dcm245 cable modem?
Hi there.
What you have to do is plug in the Ethernet hub, run the Ethernet cable (RJ45) from the modem to the "internet in" or "internet" socket on the hub, it will the one which is separated from the others.
Then connect an ethernet cable in port 1 to your first computer and a cable from port 2 to your second computer and so on.
If you experience connection problems just pull power from the modem for 30 seconds, plug it back in wait a minute and reconnect.
If you would need further assistance please post back.
Good luck and thanks for using FixYa!!
5/25/2009 1:46:01 AM • Thomson RCA... • Answered on May 25, 2009
0answers
Can some DVD players play MPEG2 files?
Most will play Mpeg2 in SVCD format, but some can't.
Why do you ask...?
4/27/2009 4:29:46 PM • Thomson RCA... • Answered on Apr 27, 2009
Whats the default username and pass
for what ???
7/4/2008 2:54:13 PM • Thomson RCA... • Answered on Jul 04, 2008
Thomson RCA DCM245R Modem Logo
35 questions posted
Top Thomson Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Thomson Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Thomson Computers & Internet
Most Popular Question
rca dcm245r modem vista
  • Computers & Internet
