20 Most Recent
Sub-Zero 561 / F Questions & Answers
Sub zero refrigerator fan wont run
Frank- another direction to try could be that either the temp sensor is faulty, thus not telling the controller that the box is over temp, so the controller is not sending power to the fan. Or the controller itself could be the issue.
Refergerator side back panel freezing up with ice
2 posibles problems. if the ice is only about 4 an 8 inches you have a seal system problem.(evaporator freon leak) need replace the evaporator asap. if the ice cove a big part of the back wall you have a thermostat problem. for replace the evaporator better call a tech. remember to call a subzero factory authorized company. maybe still under some warrantty> good luck LEAVE YOUR COMMENT IF IT WAS GOOD FOR YOU....... THANKS
Fan freezer too loud
It is more than likely that the fan motor itself is giong bad. It could also be that the blade is hitting the shorud or the blade is crackled and causing a bad vibration.
Temperature settings?
4 is the factory setting for both the fridge and freezer, but it's really just about your personal preference.
NEED ORIGINAL DOORS ON MY 561 SUB ZERO LOOKS LIKE DOORS ON FRONT
Given the model serial number I could get your decorative panels. The door itself is a framed door and designed to take a 1/4" insert. You can have new panels made if you have changed the cabinets, order stainless steel panels or put another material of your choosing. If you would like the more about the panels reply with mod and ser number which is in the freezer door jamb at eye level. Open the door past 90 degrees and look in.
