20 Most Recent
Ensoniq ES1370 Audio PCI Sound Card Questions & Answers
1371-0001-01
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Missng sound drivers
http://download.cnet.com/Creative-Sound-Blaster-AudioPCI-64V-Ensoniq-ES-1373-Audio-Drivers-version-A01/3000-2110_4-107830.html
try that or provide us with the make and model number ,
rate and let us know how it works for you
Please, Help me.....
1. Go to START, then CONTROL PANEL.
2. Look for the SYSTEM icon, click that.
3. Click HARDWARE tab, then click DEVICE MANAGER
This will display all Installed Device Drivers & Uninstalled device drivers, usually uninstalled device drivers got yellow exlamation mark icon on it.
4. Look for the Sound Device, then right click on that and click UPDATE DRIVER.
5. You need to browse for the right and proper Device Driver for this device, if not available, you need to download the Driver from the internet, and usually the sound device is provided with CD Installer, use that.
6. If all procedures were done correctly, then that should solve your problem.
If this procedure helps you solve your problemt, please spare a little time to rate my solution.
-mrsolution
Plese help meee.......
Hi, I used to have some of these cards. I have a driver called Ensoniq Vivo which might work. I will email it to you - I don't see a place to put drivers here on this site. You might also try this driver: http://www.soundcard-drivers.com/drivers/88/88810.htm
Let me know if it works!
Es1370 for win98
This is the file you want-
http://www.emu.com/support/files/storage/e64w9xup.exe
Instructions for changing internal battery for Ensoniq KT88
To change the internal battery in an Ensoniq KT88, follow these steps:
- Preparation:
- Ensure that the keyboard is powered off and unplugged from any electrical source.
- Create a clean and safe workspace with adequate lighting.
- Opening the Keyboard:
- Locate the screws securing the keyboard casing. These are usually found on the bottom of the keyboard or around the sides.
- Use a screwdriver appropriate for the screws and carefully remove them.
- Gently lift the casing, being mindful of any cables or connectors that may be attached.
- Locating the Battery:
- Look for the internal battery, typically a small coin-shaped battery. It is usually located on the main circuit board or nearby.
- Take note of the battery's orientation and any clips or holders securing it in place.
- Removing the Old Battery:
- Carefully disconnect any clips or holders that are keeping the battery in place.
- If necessary, use a small tool like a flathead screwdriver to gently pry the battery out, taking care not to damage the circuit board.
- Installing the New Battery:
- Ensure that the replacement battery matches the specifications of the original battery (e.g., voltage and size).
- Insert the new battery into the same position and orientation as the old battery.
- Secure the battery using any clips or holders that were originally in place.
- Closing the Keyboard:
- Double-check that all connections and cables are properly seated.
- Align the keyboard casing with the body of the keyboard and carefully lower it into position.
- Replace the screws and tighten them securely but not excessively.
- Powering On and Testing:
- Plug in the keyboard to an electrical source.
- Power on the keyboard and check if it functions properly.
- Verify that any user settings, presets, or system data are retained, indicating that the new battery is working correctly.
6/28/2023 2:51:01 AM •
Ensoniq...
Answered
on Jun 28, 2023
Como cancelar el winter driver
Question translated to English
Solo hablamos ingl?s en el sitio web norteamericano. Lamentablemente no tenemos idea de qui?n es este conductor de invierno. Por favor danos m?s informaci?n para ayudarte mejor. Es un problema de seguro de autom?vil, debe comunicarse directamente con la compa??a de seguros.
ENGLISH@
We only speak English on the North American website. Unfortunately we have no idea who this winter driver is. Please give us some more information to help you better. It is is a car insurance issue, you need to contact the insurance company direct.
