20 Most Recent Sony DVP-SR90 DVD Player Questions & Answers
If the TV has HDMI inputs then it will work.You will need a wifi to connect firestick to Amazon.You will need Prime to access Amazon movies.
Sony Televison &... | Answered 5 hours ago
Change language to English in Sony Bravia KDL40HX750 Yes, it is possible to change the menu language. 1.Press the HOME button, then select[Settings] at the bottom of the screen using thebuttons.
2.Select[System Settings] using thebuttons, then press thebutton.
3.Select [Language] using thebuttons, then press thebutton.
4.Select the desired language using thebuttons, then press thebutton.
To return to the last viewed source, press the HOME button twice.
Sony Televison &... | Answered 2 days ago
I'm having the same issue. Looks like the picture is in 3D mode or something. My nephew can come over push 3 buttons on the TV and it goes back to normal. But when it's off overnight we wake up and it's doing it again. Now my nephew moved to Florida and I have no idea what buttons nor in what order to fix it smh
Hello Eugene, it's always good to check the following steps:
1) -Make sure that the cables are securely connected to all of the components.
2) -Try connecting to a different set of video cables to make sure the problem is not with the current set.
3) -Verify that the appropriate input is selected on the Audio / Video (A / V) receiver.
4) -If possible, move your TV away from the audio components.
Note: Avoid plugging too many electrical items into one outlet. To avoid an overloaded circuit, try plugging some items into a separate working AC outlet. If the problem persists, you will want to verify that the outlet where the A / V receiver is connected is wired correctly.
Additional help may be to contact technical support.
https://us.esupport.sony.com/support/s/service?language=en_US
Sony Televison &... | Answered on Apr 22, 2019
Once again a simple GOOGLE search, and the first thing on the list is the manual for this unit!
I suspect this is what you need.
Deactivating the Buttons on the Unit
(Child Lock)
You can deactivate the buttons on the unit
(except for on/off) for preventing misoperation, such as child mischief.
Hold down
(stop/square black button)
on the unit for more than 5 seconds."LOCKED" appears in the front panel display.
The child lock function is activated and the buttons on the unit are locked. (You can operate the system by using the remote control.)
To cancel, hold down
for more than 5 seconds until "UNLOCK" appears in the front panel display.
If that's not the problem, here's the link for the manual.
http://pdf.crse.com/manuals/4446734151.pdf
Sony Televison &... | Answered on Apr 19, 2019
No, the remote does not know whether or not you have cable.
Sounds like the backlights are out you need to take it to a technician
Sony Televison &... | Answered on Apr 18, 2019
Hello Dear
in this case common mode coils are open which are very near to LVDS jack if these are open please change if already ok then panel is defective
Thanks
M Nsir
Sony Televison &... | Answered on Apr 14, 2019
Sony DVP-SR90 DVD Player Logo
Popular Tags
6 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
home theater not reading mp4 files
  • Televison & Video
