20 Most Recent NorStar Compact Ics WithClid Trunk Mod (ntbu0686) Questions & Answers
You need to get into voicemail administration and reset the mailbox password. Open the mailbox (F981), enter the default password (0000) and the system will prompt you to enter a new password.
Good Luck!
NorStar Compact... | Answered on Aug 12, 2010
Start with "Feature 9 (star) 1" from a Norstar telephone, to view the CallPilot Feature Code list. Then enter the System Administration feature code.
Good Luck.
NorStar Compact... | Answered on Aug 11, 2010
That happens sometimes. Try cycling the power on the voicemail system. If that does not work, you may have to replace the voicemail power supply, or send the voicemail system for repair/replacement.
Good Luck!
NorStar Compact... | Answered on Aug 10, 2010
When the incoming call goes off hook (the indicator lamp will be solid, not flashing), press the associated line button to see which extension, or device, answered the call. You can follow through from there.
Good Luck!
Hi Tommy,
I spent 13 years on the West coast of Florida, Tampa/ST Petersburg area. Also known for being the Lightning capital of the world. As such, became quite familiar with the effect fluctuating power levels had on various equipment.
During a Tech show, the power went out and we continued our demo's for over six hours with two Tripp Lite UPS's. After that, I swore by the Tripp Lite line and eventually became a dealer.
Spikes and outages were handled with flying colors. Their only short fall was line conditioning.
When a sudden draw causes a voltage drop that approaches 'Brownout' conditions, the UPS actuation threshold didn't always get reached. For some systems, that threshold was much more critical. When these were ID'ed, the remedy was a 'Line Conditioner'.
Think of it as a UPS thats always on, always charging. It outputs a regulated constant flow/ No spikes, no dips.
I feel this is your solution. However, proving it would require one being installed.
Perhaps, asking the utility company if they could check the power being supplied to the phone system for spikes/dips would be proof enough. They were happy to do this in Tampa.
Hope this helps,
Mike
NorStar Compact... | Answered on Dec 05, 2009
Yes, this is correct. install the co card with cid and you should be fine.
Dan
NorStar Compact... | Answered on Jul 29, 2009
You need to build the mailbox in f983
Log 1020000
Mbox
Add or Change.
When you get to mailbox enter the extension # of the new telephone.
When you get to extension number-enter the same extension number.
NorStar Compact... | Answered on Jan 30, 2008
HERES A MANUAL THAT MAY HELP https://www.broadconnect.ca/resource-centre/user-guides/nortel-phones/M7310-User.pdf
NorStar... | Answered on Feb 06, 2019
Hi Yazan,
You need a battery tester in order to test the amps that a battery would output. From your description, they are at their end of life and you will need new buy new ones.
Reply or call if you need more help with this -- 800.260.2259
NorStar... | Answered on Nov 01, 2013
https://www.google.com gives several obituaries with that name.
Of course, condolences if this is a personal contact.
Example:
https://www.mourningglory.ca/notices/Lois-Benneke
Computers &... | Answered 37 minutes ago
Hi Use the following code
#7465625*746*Code# ( Disables SIM lock)*7465625*746*Code# ( Enables SIM lock)
Use this code on your phone to disable/enable SIM Lock on E250
Computers &... | Answered 3 hours ago
buy a new one
Computers &... | Answered 6 hours ago
Generally, thesis would be always a lendy in everyway. Certainly, It would be consist of many component parts that you can't missed it in your thesis writing. If you are really searching for some one to help you writing in a thesis in the tourism or any specific topic then get helped here with powered essay. But the question is have you ever heard about the powered essay. Worry not, read yourself about the powered essay and their service. www.poweredessays.com/writing-thesis-statement
Computers &... | Answered 7 hours ago
First of all download the link below:
https://ninite.com/revo
then run it and uninstall the trend micro installation and any other programs like old expired anti-virus, that you don't want.
afterwards if you want an Anti-Virus on your machine you might try Avast. You can get it at the link below INSTALLED for you for free. The Avast has two versions Free and Paid. when it is installed it is free. If you want to upgrade then purchase the paid one. But I will tell you right now I cannot remember the last time that I had paid for a Anti-Virus.
Once you have Avast installed make sure you run a FULL SCAN of the HARD DRIVE. Good Luck.
https://ninite.com/avast
Computers &... | Answered 8 hours ago
NorStar Compact Ics WithClid Trunk Mod (ntbu0686) Logo
8 questions posted
Top NorStar Computers & Internet Experts
Alun Cox
Vincent G
Vincent G
Are you a NorStar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NorStar Computers & Internet
Most Popular Question
unit will not access call pilot
  • Computers & Internet
