20 Most Recent Samsung RV511A01 Notebook Questions & Answers
The brightness is lower in order to save battery power when not plugged in to the mains power supply.
To adjust the brightness and other things open the Control Panel and then click on the Display icon and select the desired function from the list on the left.
Samsung RV511A01... | Answered on Feb 09, 2018
Achi driver missing might be the issue
Samsung RV511A01... | Answered on Oct 15, 2017
go into sound settings and setup from there,or it could be were you plug your head set into could be faulty.or it could be the end bit of your head set,try another head set.
Samsung RV511A01... | Answered on Mar 30, 2015
please see video below
Samsung RV511A01... | Answered on Jan 29, 2015
Turn the machine off then back on as soon as you turn it on again press the f4 follow the insructions.
Dont forget to save any files or photos etcHope this helps because they will be gone after a reset. Make sure that you have all the drivers you need.
Samsung RV511A01... | Answered on Oct 04, 2014
Try turning it off, then upside down and checking the ventilation ports. My Toshiba will do the same over time if I do not reguraly clean the vents. Also check to see if your fan is working. The worst enemy of most laptops is heat generated but not expelled. Insure that you have adequate ventilation while using it.
Samsung RV511A01... | Answered on Sep 05, 2014
Scan for Viruses
Samsung RV511A01... | Answered on Jun 17, 2014
You will need to replace the battery. Laptop batteries lasts approximately 3yrs. This can be significantly reduced if the laptop remains plugged in most of the time.
Samsung RV511A01... | Answered on Feb 14, 2014
I solved same problem.
Just format the system tools partition 100MB/350MB and then go for clean installation (format of disk 0 and install) 99.99% you problem will clear.
Samsung RV511A01... | Answered on Nov 28, 2013
Generally Function key can be enabled from BIOS settings. BIOS settings can be accessed by pressing DEL, F10 or F2 key at system startup (depending on the laptop u have), which is prompted at screen at startup.
Give it a try
Samsung RV511A01... | Answered on Jul 27, 2013
go to control panel and use the utility system restore and go to date that you know was working good and try it.
God bless you
Samsung RV511A01... | Answered on Jul 10, 2013
Two possible issues one bad hard drive or cooling fan. Odds are its the hard drive. go and download Hirens or DBan software so that you can test any hard drive. I insert the software boot it first then do a full inspection. If you get a error message that states like this, "No drives found in order to continue" odds are the drive is bad. Also usually if you boot it sounds like grinding or groaning noise it would be the hard drive. Especially if your shut down at the boot or it keeps recycling.
Samsung RV511A01... | Answered on Jul 02, 2013
how can i adjust my screen brightness
Samsung RV511A01... | Answered on Jun 22, 2013
You are lucky that this issue is operating system based from what it seems, try to work the recovery option, let it be that way for hours. It will move at some point.
Did you have a AV installed? If not it is crucial to have an anti-virus software installed on PC.
If all the efforts appear fruitless, contact Samsung; it could be a hardware issue as well... although they are less frequently observed.
Samsung RV511A01... | Answered on May 29, 2013
Using a wireless USB adaptor
Samsung RV511A01... | Answered on May 20, 2013
uninstall driver again , and reinstalling again and see if the speaker work. The driver can be corrupt.Otherwise use the software diagnostic coming the computer restart the machine and hold the f2 or depend the model and test the sound.You can use the RESTORE system, to some date the laptop was working good. go to control panel and follow .God bless you
Samsung RV511A01... | Answered on Apr 04, 2013
only put one DDr3 and check.
Because one of the memory may be defected or incompatible or may not be fixed properly.
Samsung RV511A01... | Answered on Mar 09, 2013
This may be due to software , Or you might have over loaded or system is having virus in startup.
Also check it during power connected mode.
Check the hard drive activity if it is continuously running this may require to empty some HDD space.
only advice i can give you. a qualified technician will be able to solve your problem, he/she need to personally troubleshoot your computer.
Samsung RV511A01... | Answered on Mar 04, 2013
You can download the device drivers from the Samsung WEB site. Please click on this link and select your model computer/notebook and the Windows drivers you require :-. http://www.samsung.com/us/support/
Samsung RV511A01... | Answered on Feb 16, 2013
Samsung RV511A01 Notebook Logo
47 questions posted
Top Samsung Computers & Internet Experts
asber
Stormi  Paulk
Stormi Paulk
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
samsung rv511 laptop wont turn
  • Computers & Internet
