20 Most Recent
Nvidia ASUS ENGTX570/2DI/1280MD5 GeForce GTX 570 Video Card - 1280MB GDDR5, PCI-Express 2 0, Dual DV Questions & Answers
I have dual GTX 570 video Cards & I keep
Make sure your other fans are running also and make sure the inside of your tower is clean, no dust build up in heat sinks etc. You can also set your fan(s) on the card run manually through the Smart Doctor. What does it say the temp is? You also may want to try to uninstall then re-install the Smart Doctor and set it up again with the manual fan speed at max. Click on the settings tab, then on "fan control" tab. At the top, click on the box "manual control" then, drag the tab over with mouse to adjust fan speed faster.
Good luck,
Dave
Gt 630 nvidia, error code 43
Update your video card driver at NVidia.com. More current drivers eliminate the conflict caused by having 16GB RAM.
Need Nvidia pcg 7v1m driver Graphics win.7
go google and type in--- nvidia drivers -- download the driver for your graphics board and win 7
or if you have a graphics board already install click on the board and change compatibility to win 7 in the properties tab
you will also find an update drivers in the sam properties section
Nvidia gfx card problem
It seems that the problem lays on your Ram,not the graphic card.And since the driver of graphics card is capturing some of your ram memory you are experiencing this error.
GEFORCE FX 5500 NVIDIA PROBLEM
Official sources of Nvidia don't support windows xp anymore.Try to download the correct windows xp driver from an unofficial source.If you are not able to find one,you have to upgrade your O.S to a newest version.
