20 Most Recent
Kodak EasyShare M552 Digital Camera Questions & Answers
Why doesn't it turn on?
Batteries installed correctly?
Batteries are fully charged? Even new batteries might not be, if they are rechargeable. It is also possible, although rare, that new alkaline batteries might be bad. Try replacing the batteries. Camera's internal computer might be bad. Take the camera to local camera repair service center or check manufacturer's customer service for additional help.
Hope this helps. Mike
Free software download kodak m552
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as the free Picasa (
http://picasa.google.com ).
Why does the camera lag when i take pictures?
The camera has to do a lot of work between the time you press the shutter release button and it takes a picture. It has to determine what the subject is and acquire focus, meter the light to set the exposure, and reconfiguring itself internally from displaying the image on the screen to saving it into memory. More sophisticated (and larger and heavier and more expensive) DSLRs alleviate the problem by throwing more hardware at it.You can reduce the shutter lag by anticipating the action. Press the shutter release button halfway to make the camera focus and meter. Then, when the action peaks, press the shutter release button the rest of the way to take the picture.
Brand new out of the
Very occasionally could be power cord problem. But in this case I think there is problem in the charger. Less possible in the battery. I assume that this unit came with warranty, so I strongly suggest to give it back to seller for diagnostics.
Camera shows error message saying
The switch internal to the camera may be gummed up. But it can be easily "jogged" back open without opening the camera. You might try the toothpick or the tape fix listed in the troubleshooting steps of
this blog article.
The lens is out and
It seems 2 possible
if your battery is power off, and charger you battery and turn it on to see if every thing will get all right.
else you should to exchange the camera with the seller.
