20 Most Recent
Casio EXILIM EX-ZS5 Digital Camera Questions & Answers
Why the blitz is off n cant turn on or automatic again?
hello, has your camera hung up?
1. remove battery and put it in again
2. ensure that the battery is fully charged
3. in case the camera turns , do not do anything, just go to the set up menu and reset the camera , by pressing this camera switches off on it's own, and switches on again
4. with camera on give it a gentle whack with flat of your hand
hope it works
Will not come on
Unfortunately your camera seems like has damage on the sensor.You need contact to service center.
Free download driver
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
PIcasa.
My camera not connect to pc
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
Card locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.If this doesn't do it, try another card to see what happens.
When I turn on my
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Instructions on operation
support.casio.com > Support > Manuals
CasioIn order to use this service to download user's guides and operating instructions (manuals), you must agree to be bound by the following "Terms and Conditions.
0perating instruction
support.
casio.com/en/manual/009/qw5410.pdf
CasioThis User's Guide uses numbers shown above to identify watch hands and ..... follow the instructions in this manual, especially the information under "Operating ...
How do i unlock the card on my exilim.casio camera
Remove the card and see if the pictures remain on the camera. If they do, then they are stored in camera memory. Make sure the memory lock on the card is in the proper position. Put the card back into your computer and delete the pictures. Then format the card, and try the card again. If the card is still locked, try a different memory card that has been formatted.
