20 Most Recent
Samsung Infuse 4G Smartphone Questions & Answers
Samsung Infuse tells me no network available for phone calls
First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
My Samsung Infuse 4G doesn't want to turn on but it keeps flashing Samsung
That's called a soft brick. Either the software is extremely corrupt or more likely, a piece of hardware in the phone is dead.
Download the latest stock firmware from Samsung and reinstall in the phone. Use Odin downloader. You can get tons of info on your device from xdadevelopers.com
If reinstalling the software does nothing then I'd suggest getting a new phone
Whats the network lock control key
HI is your samsung infuse 4g is network locked then it mean your phone have been locked to any particular network provider due to this you can't use any other GSM sim in it until you unlock .You can easily unlock your phone using sites like
SimpleUnlocking.com they are rendering network unlock code for all mobile models at reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone from network lock .
I need unlock code for samsung infuse please
Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
