20 Most Recent
Canon Pixma MX360 Printer Questions & Answers
How can I change it to just print?
First check its cartridges - refilled ones do not work while faxing only if you are willing to print them manually. Printing still works ...
How to fix error 5B00 on Canon MX366
you need to reset the waste ink absorber,your absorber is full
Turn on the machine
Press MENU
Press SCAN COPY SCAN to enter service mode
USE > to got to NVRAM ACCESS
Set ABS-M LEVEL to 0
Set ABS-P LEVEL to 0
Press STOP to EXIT
How Do I Fix Printer
on the side of where the cartridge is mounted there is a release that allows the door to open. well its broken not allowing it to open thus the cartridge will not go far enough to open. its on either side in front.
How do i scan with the mx360 ?
Mak sure the scan drivers are installed on your PC. They are different than the print driver. Then push the scan button and then choose either the color or black button.
How do i fix my printer when it says printer error has occurred
You might add more information to your question, but a general approach to this sort of thing is to unplug the device, let it sit for 10 minutes or more, then plug it back in and try it again. Sometimes, if it's just the electronics stuck in a confused state, doing this will reset the device. This has worked for me for dryers, dishwashers, televisions, etc.
Canon MX360 shows code 6000. Have switched of printer and computer and the error is still there. What do i need to do?
sounds like the gearing is out of sync. When you remove debris did you force any of the geared rods? some times if a printer has been jammed by debris i.e. your paper clip, the gearing gets out of sync as gears jump teeth. In the past I've rectified this problem by rotating gearing manually. Its a hit and miss method. try it " WITH NO POWER " to the printer. Put a sheet of paper in tray and rotate gearing by hand and watch closely all movement, pick up rollers, paper feed, head movement path etc. you'll get a feel for it .
once you get paper feeding manually try it with power.
good luck.
How do i clean drum of mx 360
The Canon MX360 doesn't have a drum. The printhead and platen can be cleaned through the maintenance programs built in.
Canon mx360 poor colour photo
Are you using Canon inks and papers?
If not go to the manufactures website and see what settings should be used.Most photo paper from other companies recommend using the matte paper or hi-resolution paper setting.
