20 Most Recent
Traulsen 46 cu. ft. / 1303 liter Commercial Freezer G22010 Questions & Answers
Traulsen 6 half door moel 31300 freezer
To check if the expansion valve is faulty in your freezer, you can follow these steps:
- Safety Precautions: Ensure the power is disconnected and the freezer is fully defrosted before proceeding.
- Locate the Expansion Valve: The expansion valve is typically located near the evaporator coil in the freezer. It is a small valve with an inlet and outlet.
- Visual Inspection: Inspect the expansion valve for any visible signs of damage or leaks. Look for corrosion, loose connections, or frost accumulation around the valve.
- Temperature Measurement: Use a thermometer to measure the temperature at different points in the refrigeration system. Check the temperature at the inlet and outlet of the expansion valve. There should be a noticeable temperature drop across the valve.
- Pressure Measurement: If you have the necessary tools and experience, you can also measure the pressure at the inlet and outlet of the expansion valve using a pressure gauge. Compare the pressure readings to the manufacturer's specifications to determine if the valve is functioning properly.
- Consult a Professional: If you are unsure about performing these checks or don't have the necessary tools, it is recommended to contact a professional technician or an authorized service center. They will have the expertise and equipment to accurately diagnose and repair any issues with the expansion valve.
6/28/2023 5:23:12 AM •
Traulsen...
Answered
on Jun 28, 2023
Solenoid diagram
that sounds like the hardstart relay that energizes the start windings in the compressor . if that or more likely the capacitor fails when it is first energized the compressor will pull excessive amps and cause the overload protector to open until it cools for a minute or two.
5/22/2014 5:40:12 AM •
Traulsen...
Answered
on May 22, 2014
