20 Most Recent ASUS VH197D LCD TV Questions & Answers
Please help me for may
For the ASUS VH197D LED Monitor, turn it upside down so you are looking into the base of the stand. Squeeze the plastic tabs to unlock the base and pull. This will remove enough of the base to make it wall mounted and you can quickly attach the base if so desired. If you want to permanently remove the base and stand, remove the two screws that are now visible after the base is removed and pry out the plastic stand. This will break it off at the hidden screws. You will be left with a short metal stub that can be folded in.
3/17/2012 1:14:55 PM • ASUS VH197D LCD... • Answered on Mar 17, 2012
I need help removing the
3/17/2012 1:13:04 PM • ASUS VH197D LCD... • Answered on Mar 17, 2012
How to remove the stand/base for wall mounting.
there usually are two or 4 little screws on the bottom of the base or on the side where it connects to hte monitor some actually have a press button release on the back let me know if this helps!
3/17/2011 7:29:42 AM • ASUS VH197D LCD... • Answered on Mar 17, 2011
Asus transformer/tablets blinking power lights; What do the different colors and combos mean?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://homenol.blogspot.com/ https://electronicshelponline.blogspot.com/ If blinks continue without any pause, or the LED light stationery; the main board is faulty. Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview'/
8/11/2018 3:51:18 AM • ASUS Televison &... • Answered on Aug 11, 2018
Is ASUS CM-16 compatible with verizon fios
That device has the capacity of about 700 Mbs. The fiber cable wont come all the way into your house. There is a point called Dmark that it stops and changes over to conventional wire. That device will work fine.
12/24/2017 2:59:56 AM • ASUS Televison &... • Answered on Dec 24, 2017
Asus vk266H Hi my monitor (ASUS
The backlight driver could be going bad. The ballast control board most likely is the culprit.
10/30/2017 4:44:53 PM • ASUS Televison &... • Answered on Oct 30, 2017
How do I get rid of grid lines on my Asus computer monitor? I have had it less than one year.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Screen-shots to defective LCD panels are given. You can see and compare to that to your device, and can make sure about the fault to an extent.
10/9/2015 10:57:19 AM • ASUS Televison &... • Answered on Oct 09, 2015
Printer spooler not working google cloud print
https://support.google.com/cloudprint/faq/2541828?hl=en
3/23/2015 8:46:45 PM • ASUS Televison &... • Answered on Mar 23, 2015
Motherboard
pc failure?replace PC
4/18/2012 8:24:07 AM • ASUS Televison &... • Answered on Apr 18, 2012
ASUS VH197D LCD TV Logo
6 questions posted
Top ASUS Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ADMIN Eric
ADMIN Eric
Are you an ASUS Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Televison & Video
Most Popular Question
need help removing
  • Televison & Video
