20 Most Recent
Vizio M470VT LCD TV Questions & Answers
Audio out
Look for a red and white RCA plugs on the back of the TV. It would be marked Audio Out. Otherwise, if your TV has a mini-plug for a headphone that will also work for audio out. A headphone jack could be on the front of the TV or back.
Turns itself off and back on repeatedly.
That is rough---usually issues like you describe do not happen so soon in a set's life but in shop where I work 100 plus sets LCD and Plasma at any time in for repair---85 PERCENT are less than 2 years old.Some simple things just to try--unplug it and or a cable box if using one as they will after sitting a short time without power when plugged back try to reboot--easy and worth trying.can you give me a better idea : is it constant on/off or does it shut off and come back after being on a while?You are aware but I am not of what pattern this follows.Afterthought, the company I work for is authorized Vizio-we have had customers come in with no receipt and just did the work and were creative with the paperwork--warranty stations will do this as they get paid something for every set under warranty. All they need is the model and serial number on the unit to file a claim and get paid.
Vizio V705-H1 started having display issues. The background seems okay but words have tracers.
Check Connections:
Ensure that all cables connecting your TV to external devices (such as your cable box or gaming console) are securely plugged in. Loose connections can cause display anomalies.
Test Different Devices or Apps:
Try using other devices or apps with your TV to see if the issue persists. If the TV's menu looks fine but a specific device is causing trouble, that device might be the culprit.
Adjust Picture Settings:
Navigate to the picture settings by pressing the 'Menu' button on your remote.
Experiment with different picture modes. Sometimes a minor adjustment can resolve display problems.
Soft Power Cycle:
Unplug your TV from the power source.
Press and hold the power button on the TV for about 3-5 seconds (this helps drain any residual power).
Plug the TV back in and turn it on. Some TVs also have a 'Soft Power Cycle' option in their settings menu, so check there too.
As you have tried a reset, that takes us to the options of contacting Vizio support and/or your warranty.
Vizio all in one computer VIZIO CA-27 voltage and part number for subwoofer/power supply replacement
The power supply/subwoofer for the VIZIO CA-27 series all-in-one PCs is identified by the part number 715G6960-P02-001-002S or ADTVE1825AC71. The power supply connects to the motherboard via a proprietary dual jack Audio/Power cable. I couldn't find specific voltage details for the subwoofer/power supply in the available resources. For precise information, I recommend checking the user manual or contacting VIZIO customer support directly.
Why is my Vizio TV stuck on mute.
The one logo is coming from the set top box that is supplying the signal, cable box, satellite box, Android box etc. Look for Mute on that remote, or cut the power to all your devices by removing the wall plugs. Wait 15 minutes and plug back in.
How do I fix a Vizio TV?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
