20 Most Recent
Quantum Atlas IV (QM309100KN-SCA) 9.1 GB Hard Drive Questions & Answers
Need to know the slave jumper for the quantum
If the drive you're referring to is the SCSI model, it doesn't have a "slave" option, but can be set to various SCSI ID's.
Click this link to get the skinny on all your jumper options:
http://support.dell.com/support/edocs/storage/6848p/Jumpers.htm
If you are using it on an older MAC it should work fine set to ID 1, if you want to use it on a PC check first if the PC even has a SCSI connector(rare for PC's of the same age as that drive as they primarily used IDE). The cables look almost identical but are in no way compatible
Hope this helps FixYa
Chris
Armor-IT
Quantum Superloader 3 - Medium Changer missing.
If the Medium Changer is missing from Device Manager on your Windows Server 2016 system, it is possible that the driver for your Quantum Superloader 3 is not installed or not functioning properly. Here are some steps you can try to fix this problem:
- Check the driver installation: Make sure that the driver for your Quantum Superloader 3 is properly installed on your system. You can check this by going to Device Manager and looking for the "Tape Drives" or "Medium Changers" section. If the driver is not installed, you can try downloading and installing it from the Quantum website or from the manufacturer's CD that came with your tape library.
- Update the driver: If the driver is already installed on your system, you may need to update it to the latest version. Outdated or incorrect drivers can cause problems with device recognition and functionality. You can check for updates to the driver by going to Device Manager, right-clicking on the Quantum Superloader 3, and selecting "Update Driver" from the context menu.
- Reinstall the driver: If updating the driver does not fix the problem, you may need to uninstall the current driver and then reinstall it. To do this, go to Device Manager, right-click on the Quantum Superloader 3, and select "Uninstall Device" from the context menu. Then restart your system and install the driver again.
If these steps do not fix the problem, you may need to contact Quantum customer support for further assistance. They will be able to provide more specific troubleshooting steps based on your particular tape library model and setup.
12/10/2022 12:35:34 AM •
Quantum...
Answered
on Dec 10, 2022
Sage 50 Quantum Inventory Valuation Report
If you are in need of a Sage 50 inventory valuation report, there are a few different options available to you. You can either purchase a pre-made report or create your own report using our software. Both options have their advantages and disadvantages, so it is important to choose the right one for you. If you decide to create your own report, be sure to follow our guidelines to ensure that the report is accurate and reliable. If you need to create a Sage 50 Inventory Valuation Report, there are many options available to you. You can choose to use the default report, or customize it to suit your needs. The report includes information on the company's assets, liabilities, and revenues. You can also add notes to the report if you want. You can download the report as a PDF file, or export it into various other formats. Source:
https://www.isopentoday.com/sage-50-inventory-valuation-report/
