20 Most Recent HEWLETT-PACKARD HP ENVY 15 Series Notebook (Intel Core i7-920XM Quad EXTREME Processor - 2.00GHz with TURBO BOOST to... Questions & Answers
How do I use my hdmi to vga converter on my envy 15
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 ASUS and Dell = Fn + F8
4/6/2013 4:40:44 AM • HEWLETT-PACKARD... • Answered on Apr 06, 2013
Hp envy 15 fan error
Hihere is the link to dissasemble the unit http://www.insidemylaptop.com/disassemble-hp-envy-15-notebook-replacing-keyboard/please put all crews back in the right place and wear esd wrist strap.take the radiators off use tim thermal compound cleaner then dissasemble the fan and take out the dast particals.then blow the radiator out with electric solvent cleaner so nothing gonna remain between the plates.then assemble the fan back and apply new thermal compound just on those parts where was.leave the silicon pads.if they are broken or old you have to replace them.usually the latest hp laptops having problem with bearing they just dry out i use wd40.you need just one drop in the right place.
3/21/2013 3:56:57 AM • HEWLETT-PACKARD... • Answered on Mar 21, 2013
2answers
My dvd rom is not working becouse an error in driver HPDVDRAM GS30
Optical drives are more forgiving. Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install.
12/15/2012 5:08:30 AM • HEWLETT-PACKARD... • Answered on Dec 15, 2012
Which port on my HP Envy 15 (HDMI, USB, eSATA are
You'll need to get a hdmi to vga converter like this one.
4/16/2011 4:57:39 AM • HEWLETT-PACKARD... • Answered on Apr 16, 2011
2answers
When I try to download into quicken the documents page comes up. How do I correct this situation?
If your bank statement is not in the Quicken format, you cannot do that. Best see if it will download into MS Excel. If not, get in touch with the Bank
10/19/2022 4:47:44 AM • HEWLETT-PACKARD... • Answered on Oct 19, 2022
3answers
Back Slash on HP keyboard ProBook
Try now~ Then you can reset your keyboard if you like
5/4/2022 2:32:08 PM • HEWLETT-PACKARD... • Answered on May 04, 2022
HP G72-253NR Laptop - Using an External Keyboard
I think you have a broken USB keyboard or USB port. Simply plugging in the keyboard should be enough to make it work. First try the keyboard in a different USB port. Test the caps lock to see if the LED goes on and off. Also try a different keyboard and also test it in a different computer.
1/31/2019 6:37:16 PM • HEWLETT-PACKARD... • Answered on Jan 31, 2019
Pano pag ang laptop sa HP ay hindi na mag on pero meron syang power?
please use English, ok?
10/30/2018 1:04:04 PM • HEWLETT-PACKARD... • Answered on Oct 30, 2018
3answers
User manual Hewlett-Packard G2 tablet or the instruction booklet
https://support.hp.com/us-en/product/hp-10-g2/8223709/model/9078231/manuals
this is the manual pdf just download it
10/1/2018 11:15:14 AM • HEWLETT-PACKARD... • Answered on Oct 01, 2018
2answers
My Hewlett-Packard w2207 monitor is showing no input signal when I power it on what does that mean and how can I fix it
1) Reset your computer. 2) Unplug the cable from the computer to the monitor and check to see if its damaged, if OK plug it back in. 3) On windows computer, click windows key / windows system / control panel / device manager / display adapters (click on icon) / Update driver
5/1/2018 3:23:11 PM • HEWLETT-PACKARD... • Answered on May 01, 2018
HP A6519FH Black Screen Issue: I
what computers.?? 1000's of models over 30 years. made F10 is BIOS screens, so if that works, BIOS. and any screen then the PC is not booting. try booting to CD? *(a free linux live cd?) as a test. if that works run HDD tests. next ill stop here, if you can get this far, we go to next step F11 HDD reload the OS, if PC is 2006 or newer from HP.
2/1/2018 12:20:26 PM • HEWLETT-PACKARD... • Answered on Feb 01, 2018
Ce 3700, no model HP stated
Try again with the model number
1/30/2018 12:32:03 PM • HEWLETT-PACKARD... • Answered on Jan 30, 2018
My laptop hp compaq 6715s, the battery is charging
what is a device? did you mean PC, a collections of devices and chips:? a PC Is not a DEVICE it is a system.(or machine) why in the world not buy a new battery first? if charging fails. mine sometimes go bad even 1 year old, when I abuse it. and I fully expect that, if you read the battery makers pages, youd learn how that happens' (cycling the snarf out of it) if i remove the word DEVICE and add LAPTOP OR PC THE ANSWER IS THIS. IF the Pc does not run with the battery (main big) out ! the power pack is bad. the PC will run forever on AC power, a fact, !!! I do so all the time, or even the wrong AC pack used, (mixed up with other pc:) get a new pack, get one matching your systems, needs (watts) the laptops can come with 5 processor options and 4 graphic chip options, the worse mix is 100watts, HP will tell you that match. but only if YOU tell your full service tag data.... that magic, nnnnnnnABA# number tells the HP pro what is inside this laptop and what power park is right or just buy the 19v, 100watt pack. here is real HP, fixya is NOT. they can match you up as can the hp PARTS SURFER, https://h30434.www3.hp.com/
1/24/2018 1:56:50 PM • HEWLETT-PACKARD... • Answered on Jan 24, 2018
2answers
How to fix the sound of HP pavilion dv6345us
sure, get the Correct HP driver for this exact pc but, but but...The windows sounds are dead. (do that yet>, CP + sound test)CP = control paneltry to know , most HP made, dv6345us, can have 3 sound chips as an option day 1 new!what you have is clearly stated in the service tag that you did NOTpost, the number ending in ABA# is THAT number.the chip and PC and the unstated OS all must matchwindows what? you never said so i cant match that either.VISTA????????? vista 32 bit or 64????????but the other way is what, sure, guess.read the drivers at HP and try all there.for sound chips (aka audio)This HP computer is 11 years old. now. (2007)HP dropped most support on it this old, (SOP) one sound chip is Conexant AC -Link Audiolets say you said (service tag) RV214UA#ABAand you said VISTA> what works there.the secret is deep, lacking full spec, from HP.finding Conexant drivers is not easy, lots of hits all virus sites now.lets first look .does device manager show it as bad.CP+DM see sound there. is it red, yellow or Unknown marked.go to CP again control panelclick sound is the Conexant still there.the window for sound has a speaker is it selected?select speaker then properties lower right.then pick enhancementshit checkmark, disable all sound effectsclick tab levels, turn up volume.can you do all that, i bet not, its got bad drivers for this chipVISTA btw is dead so asking MS to update driver is dream of dreams, hopeless, now and for sure forward.you dont have the HP install disks so that source too is missing.,leaving you , VISTA and MS and HP and conexant in the lurch.if microsoft was not dead and your internet was alive (is it)the remove the driver, and reload, it under device manager.it then magically PnP reloads from MS but not if the MS driver servers are off line as they sure are. (1/2 or all) (ms secret this is)Hard this is,::::, 1ST OFF, is HP ended support,ON YOUR PC NOW.2nd VISTA support has ended at MS. (double dead)3rd factor (bad) IS Conexant maker of chip and their Driver. IS DEAD. TRIPLE DEAD.SHORT WHY>?synaptics Bought out Conexant in 2017, and shows no support NOW. FOR THAT. the Snaptics web site lists nothing on the words driver or conexant. zero support, but do call them,,,? SO that ends that foray. leaving all those malwares sites offering this driver, only. ? many we can find it this magical way. the FAMOUS DRIVER PACKS site. (all safe ask) the one place on earth with no malware is here.this is the vista set 32bit only 64 is on other pagethere are 15 drivers for Conexant. there. get them try them.end storyhttp://driverpacks.net/driverpacks/windows/7/x86/audio/11.11
1/5/2018 4:29:57 PM • HEWLETT-PACKARD... • Answered on Jan 05, 2018
3answers
How do i take a screen shot
There should be a button on your keyboard labeled "PrtScn". It stand for "Print Screen". This will copy an image of your screen. Simply open Microsoft Paint or a similar software and select paste. Your screen shot should appear in your chosen software.
1/2/2018 8:44:11 AM • HEWLETT-PACKARD... • Answered on Jan 02, 2018
I installed validity driver version.
NO PC stated (model name and full number) NO OS stated, is this XP? must we beg you to get hard key facts like this>? what are you attempting, ? the Finger print reader has many features, which one are you attempting? yes, it can work but only works on matching PC and matching OS. the HP pages there warn you,.it only works on the OS sold with PC. (eg vista or w7) HP web site on your PC is clear, ever look there? my HP 8540w , works perfectly with W7 but not w10 ! i can not use the reader nor the security package, ever. But w10 is happy there , FP reader stuff removed. HP will not revise these drivers and apps for W10 ever. see my point? In my example case. there are 2 parts, the FP reader, driver. and the security package ( vastly huge and complex !) i say why use it at all? do you have secrets on your PC? (you 007 agent?) 008? or your soon to be published book ? (huge value) or engineering work/ cad/cam, etc. or valuable art, (or music composer) or you are CEO or FCO with sensitive data? (accountant?) if no, then avoid that. The reader is safe but not the security HP applications: look in the registry at all that complexity, and risk for that. you can use the reader to block BIOS boots. dead. block the windows, login page. or block specific apps, or all 3. is say don't do it, at all. But all that works on mine 100% on w7 only. it does work but is still risky. other apps do not like it , etc.
12/19/2017 2:41:37 PM • HEWLETT-PACKARD... • Answered on Dec 19, 2017
ProBook 4420s shuts down randomly
so you are asking for a 3rd party, really? no OS stated, wow, must we guess that?windows what?BIOS test, or inside windows, if inside what way did you do that? tell how? running the extended memory diagnostics test.the mem test fails.there are many ways for that to fail.but if the BIOS memory test fails, gee say so. say BIOS. if in windows, and it's corrputed why in the world run mem test in any corrupted OS? as XP surely is.BIOS RAM TEST: (tossed the big coin there, lands BIOS)then the ram is failingcaused by.1; Bad ram. take them all out and test them 1 by 1.2: wrong ram, used, very common on old PCs3: the power supples to the ram are weak.4: there are modules on the mobo that can be shorted causes effect #3 above, strip the PC down to just nill and test. cd out, hdd out, all extry ram out. modem card out, wifi card out, all moduels out but CPU and 1 stick of ram.pass mem test now?, if not, the mobo is dead.one needs one known good ram stick to prove this.see why? many are not for sure used or from old systems.may makers of ram do not make ram for old computers now.making repairs hard.the RAM needs to match 1 of 6 CPUthe fast one isIntel Core i7-620M Processor it must be 620m compatible and for speed.Upgradeable to 8192MB with 4096MB SODIMMs in slots 1 and 2to use full size windows 64bit must be used.buy 1gb stick and test with that, first.cheap stick fast test.ddr3204pin PC3-10600(i have no idea at all what processor is there)so.... i go worst case for you.a cheap test memory (if your pc lacks 2 sticks)is here or at amazon for $5https://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=PC3-10600++ddr3%2C++204pin+1gb&_sop=15
9/18/2017 4:28:10 PM • HEWLETT-PACKARD... • Answered on Sep 18, 2017
2answers
Slow download speeds
the wireless signal can be strange, do both computers display the same signal strength ? Are they both connected at the same speed ? Small variations can make a big difference
9/5/2017 6:22:22 PM • HEWLETT-PACKARD... • Answered on Sep 05, 2017
HEWLETT-PACKARD HP ENVY 15 Series Notebook (Intel Core i7-920XM Quad EXTREME Processor - 2.00GHz with TURBO BOOST to... Logo
Popular Tags
7 questions posted
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HEWLETT-PACKARD Computers & Internet
Most Popular Question
hp envy 15 fan error
  • Computers & Internet
