20 Most Recent Ricoh KR-5 SUPER II 35mm SLR Camera Questions & Answers
2answers
Ricoh KR-5 light meter needle won't move, new batteries
About the only thing you can do is clean the batt. cover and contacts in batt holder. Make sure batts are good. No parts are avail. for this model. However this is a rugged camera and you can buy a hand held light meter inexpensive.
1/17/2023 1:23:21 PM • Ricoh KR-5 SUPER... • Answered on Jan 17, 2023
Can the 35mm SLR Ricoh
Straightforward answer: no. Everything needs power to work except for the self timer, but even that won't fire the shutter without battery power.
1/6/2023 2:40:08 PM • Ricoh KR-5 SUPER... • Answered on Jan 06, 2023
Ricoh kr 5 super ii mirror
There are some wide angle lenses that will hit the mirror and not allow it to move correctly. Wide angle lenses go further back on the film plane, so they can't be used with that camera. Try a Pentax.
2/21/2018 9:38:11 PM • Ricoh KR-5 SUPER... • Answered on Feb 21, 2018
2answers
Lite meter don't work I bought it off internet seller said it was in exl.cond.it looks that's all
The built-in through-the-lens CdS exposure metering system of your KR-5 SUPER operates on power activated by two 1.5V SR-44 silver oxide batteries, which are supplied together with your camera. Have you changed the battery? Also, many of these older cameras the light meters are not very good. I would suggest getting one of the free smartphone light meter apps.
1/5/2016 10:53:30 PM • Ricoh KR-5 SUPER... • Answered on Jan 05, 2016
How do I remove film from the camera?
wow a film camera!!!! , didn't know any of these still existed (less than 60mm) anyways you'll need to rewind the film back into housing , this is done with tiny crank on top of film advance wheel (don't go to fast !!!) slow and steady wins the race!! you'll also need to activate the shutter release lever (around the crank someplace) DO NOT OPEN CAMMERA TILL YOU HAVE REWINDED ALL THE FILM INTO HOUSING !!!!!!!!!!!! it will ruin all the photos
12/1/2015 12:12:00 AM • Ricoh KR-5 SUPER... • Answered on Dec 01, 2015
The mirror only returns when lens removal, it appears that on his return back it locks when the lens is at infinity. Maybe problem whith the mirror glue???
Sounds like the back of the lens may be sticking too far into the mirror box and interfering with the mirror travel. There are also a couple of bumpers on the bottom of the mirror box, and the plastic has become soft and breaks off, allowing too much travel for the levers. Try another lens first. If it does it with all lenses then you will have to search out a repair facility that still does something so old.
3/25/2014 11:00:27 PM • Ricoh KR-5 SUPER... • Answered on Mar 25, 2014
Light meter won't move
Check you battery ends and make sure there is NO corrosion. An emory board works good.....also check the contacts in the camera well.
1/22/2014 2:20:08 AM • Ricoh KR-5 SUPER... • Answered on Jan 22, 2014
Do not have crank rewind any longer. Cannot find one and dont know if I should give up or not
I think there is a special forum for normal foto cameras on fixya to. I can't see any digital problem here.
11/6/2013 1:18:28 PM • Ricoh KR-5 SUPER... • Answered on Nov 06, 2013
2answers
How do I remove the lens?
See the instructions on page 20 of this manual.
2/8/2013 5:06:04 AM • Ricoh KR-5 SUPER... • Answered on Feb 08, 2013
0answers
When I bought this camera
From what you've given, it sounds like the shutter is fried, or the mechanism jammed - or both. If you're wanting to keep the camera, and use it, you'll need to contact a repair technician and have them take a look at it for a repair estimate - assuming it's able to be repaired. Estimates will run you around $35 most places, if there's no shop near you KEH Camera which has a website is quite good.
The same thing just happened to my Nikon FE, and my estimates have been ranging anywhere from $105-145 to get it fixed, so the decision of whether to repair or replace if really left up to you.
9/9/2011 2:59:39 AM • Ricoh KR-5 SUPER... • Answered on Sep 09, 2011
Battery #
Your camera takes two SR44 batteries. LR44's will also do and are cheaper, but the exposure meter will not be as accurate as they have different voltage characteristics.
You may wish to download a free copy of your camera manual courtesy of Norman Butkus; it's only fair to point out that providing this information costs him money so please consider his request for a token voluntary donation of $3 US if the information is of use to you.
3/6/2011 5:26:01 PM • Ricoh KR-5 SUPER... • Answered on Mar 06, 2011
Ricoh KS Super II 35mm
If the batterys are ok ,try rotating the speed control to X and the mirror will unlock from its upper position and the film will advance next time you try. Also the camera will not operate unless the leaver is moved away from its rest position, ie level with the camera body to its first movement area.
12/31/2010 5:23:27 PM • Ricoh KR-5 SUPER... • Answered on Dec 31, 2010
Ricoh KR-5 SUPER II 35mm SLR Camera Logo
Popular Tags
56 questions posted
Top Ricoh Photography Experts
ExpressFiX
ExpressFiX
ADMIN Eric
ADMIN Eric
Are you a Ricoh Photography Expert? Answer questions, earn points and help others
View Most Popular
Ricoh Photography
  • Ricoh Photography
Most Popular Question
remove lens
  • Photography
