20 Most Recent Samsung Slim Zoom 1150 Point and Shoot Camera Questions & Answers
What is mode ?
Mode is a behavior setting for the camera. The most common is "automatic" and this will rely on the camera to adjust settings like shudder speed and focus. But sometimes you need more control...
"Night" - will assume you need a very long shudder speed. while the camera will take pictures in lower amounts of light, you also have to work harder to keep the camera still.
"Portrait" - This mode will adjust the automatic focus assuming that regardless of activity in the background that you want a picture of the object or individual directly in front of the camera
"Video" - Takes low quality video instead of high quality still shots.
"Landscape\Panoramic" - This setting is the opposite of portrait and assumes that the landscape is the main focus of the picture regardless of activity in front of the camera.
Other Modes: Cameras may have other modes that similarly allow for specialized photos. Some examples would be Black and white, color filters, light filtering, and overlays.
3/26/2010 1:02:21 PM • Samsung Slim... • Answered on Mar 26, 2010
What does LP stand for
Have studied the Manual carefully for possible error codes? If you are not getting a result there the try the Technical Support Team at Samsung
2/21/2009 11:36:54 PM • Samsung Slim... • Answered on Feb 21, 2009
Broke the external lens on my slim zoom 1150 samsung camera
I have a slim zoom 1150 I can sell you for parts.
12/30/2008 11:19:07 PM • Samsung Slim... • Answered on Dec 30, 2008
0answers
0answers
Need manual
Be the first to answer 11/6/2013 11:06:07 PM • Samsung... • Posted on Nov 06, 2013Be the first to answer
Protection appears across screen and wont let me
The media you are using has the recording protection on.
12/15/2009 6:33:19 PM • Samsung... • Answered on Dec 15, 2009
Samsung Maxima 105 zoom
I have the manual. I'll scan it for you & email it. My problem is that the manual doesn't identify the batteries & I lost the ones I'd removed for storage.
2/24/2009 6:16:32 AM • Samsung... • Answered on Feb 24, 2009
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old. If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load. I would get it serviced at an aurgorised Minolta repair shop. Contact Minolta for a list of authorised repairers.
3/22/2024 7:04:40 AM • Photography • Answered on Mar 22, 2024
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
  1. Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
  2. File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
  3. Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
  4. Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
  5. Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM • Photography • Answered on Mar 16, 2024
I lost one of the little rubber ball-like feet off my tripod 1612201. Do you have them available?
We don't have anything available Elizabeth. We are Fixya, and we only supply free information. It would be useful to know the maker as the '1612201' doesn't bring much up and looks like a serial number. Your local camera shop can get them, or you can get online. https://www.google.com/search?q=tripod+feet+replacement //
2/9/2024 6:10:43 AM • Photography • Answered on Feb 09, 2024
2answers
Need OptiPix Pro software
I own the OptiPix DPF and here is a pic of the owners manual with directions for the OptPixsetup file. img_20231124_190238_785-45plut3dk5rkrmoi0ue4e000-d-0.jpg
11/25/2023 1:11:02 AM • Photography • Answered on Nov 25, 2023
Smartparts SPDPF84M 8-Inch Digital Picture Frame. I need to purchase a remote for model SPDPF84M. How much will it be please?
Question edited for a lot more clarity, 'make model (what it is)'. Question moved from Televisions to Photography - Digital Photo Frames. $35 for a new one.
SMARTPARTS SPDPF84 Replacement Remote Control
Remotes.net https://www.remotes.net > products > replacement-rem... The RTSPDPF84 is a custom-built replacement remote control to the original SMARTPARTS SPDPF84. It will perform all the functions that the original ... US$34.90
Replacement Remote Control for SMARTPARTS ...
Amazon.com https://www.amazon.com > Replacement-Control-SM... This is a custom built replacement remote made by Redi Remote for the SMARTPARTS remote control number SPDPF84. *This is NOT an original remote control. US$34.95 ..
11/25/2023 12:40:58 AM • Photography • Answered on Nov 25, 2023
Samsung Slim Zoom 1150 Point and Shoot Camera Logo
8 questions posted
Top Samsung Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Photography Expert? Answer questions, earn points and help others
View Most Popular
Samsung Photography
  • Samsung Photography
Most Popular Question
mode
  • Photography
