20 Most Recent Aqua Signal LED All-Round Anchor Light Questions & Answers
If all you have is a green and a brown and they don't tell you which is which, it won't matter. All you are doing is completing a circuit and the light isn't picky. I would use the brown as positive though. The only way it might make a difference is if the light itself has a ground wire. If this is the case, use an ohms meter and touch the end of the brown wire to ground and if it is open, your ok.
Aqua Signal LED... | Answered on May 14, 2011
I think there is a nut holding the prop to the shaft and there might be a shear pin going through the prop and shaft. Remove those to get the prop off. It may have been on so long, there might be rust and other junk holding it on. Spray with penetrating oil and let sit to loosen the rust.
Boating | Answered on Oct 31, 2019
I suggest you post your question on this forum:
http://www.boatered.com/forum/topic.asp?TOPIC_ID=131726
Boating | Answered on Oct 30, 2019
I suggest you go to this site and obtain a manual for your Evinrude engine. Hope it helps:
Literature
In demo mode, it will show fish and bottom details when the transponder is out of water. If the boat is in a mooring, put a metal spade under the transponder, you should see the detail change.
Google
make model manual
Boating | Answered on Oct 28, 2019
https://www.lowrance.com/en-au/help--support/fishreveal-software-upgrade/
It wont hurt to update any software,
Hope it works out,
cheers.
Boating | Answered on Oct 27, 2019
Sounds like one of the pins on the cable from your transducer is bent where it plugs into the back of the unit. check that first, then ensure the plug is all the way in. If it's not that, it's possible a wire is broken in the cable. You could try the wiggle test. With the unit on, have someone watch the screen and wiggle the wire that you can reach working from one end to the other. if the screen flashes or changes while you do this in a certain spot, there's your problem. This kind of problem usually comes from the wire being tight where it goes around a corner. Heat and vibration will finish the job
Boating | Answered on Oct 26, 2019
Try the following.
Ensure the connector going to the controller is secure.
Remove power to the motor by stowing it. Wait until the remote screen goes blank. Deploy the motor to power it up verifying that the System Ready light comes back on when the motor is deployed.
Press any button on the remote to turn it on.
If F code returns then probably controller board will need replaced.
Once a Honda has an oil spill ti seems like forever before they stop dripping. on the larger ones, we would remove the side cowlings and use a degreaser and wash them out.
Let it dry out. Then check it on dry land. You need to reseal the motor before putting it in the water.
If it just blowing the fuse at one speed or top speed it could be a short in the speed control or the negative cable is dirty. clean up the terminals and try again.
Hello, The owner manuals that come with the boats are so basic that you could use anybody's manual. if you need help in anything just ask.
It should be about 525 lbs dry weight.
Boating | Answered on Oct 22, 2019
If you are really interested, check to see if a library has this book : Chronometer Makers of the World by Tony Mercer. It should have info on the year of manufacturer.
Boating | Answered on Oct 20, 2019
and what is your question?
Boating | Answered on Oct 17, 2019
Aqua Signal LED All-Round Anchor Light Logo
1 questions posted
Top Aqua Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Aqua Boating Expert? Answer questions, earn points and help others
View Most Popular
Aqua Boating
  • Aqua Boating
Most Popular Question
light instructions sure
  • Boating
