20 Most Recent Samsung Digimax 350SE Digital Camera Questions & Answers
Hi, A friend gave me
Welcome to Fixya
Try the alternate way of transferring the pictures to your computer instead of using cable.
To download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer. Once the card is plugged in, it will appear to your computer as a removable drive. Just drag&drop pictures from the card to the computer's hard drive, the same way you copy any other files.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
5/18/2011 2:18:33 PM • Samsung Digimax... • Answered on May 18, 2011
I'm trying to download my
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
4/27/2011 12:48:55 AM • Samsung Digimax... • Answered on Apr 27, 2011
Driver for windows 7?
Your camera is so old and obsolete that there aren't any Windows 7 drivers and never will be.
All you can do is to try and run the existing drivers using the compatibility mode of Windows 7, if that fails then you must either update your camera or find a cheap old basic laptop or pc running an earlier version of Windows. Often you can get them for free on FreeCycle.
3/6/2011 5:53:34 PM • Samsung Digimax... • Answered on Mar 06, 2011
Digimax 350 SE driver on vista.
Microsoft has confirmed that the latest driver for the Digimax 350 SE is compatible with Vista. Source: Windows Vista Compatibility Center.
Download the latest Digimax 350 SE from Samsung here.
8/31/2009 2:05:35 AM • Samsung Digimax... • Answered on Aug 31, 2009
Lens do not comes out. Fell in the floor. need service center to
where are you?
5/3/2009 2:52:19 PM • Samsung Digimax... • Answered on May 03, 2009
Samsung digimax 350se- i am having problems getting pictures off of camera
i do not have the software from the camera (cd) and my computer is no recognixing the camera, is there a website i can go to download this software so i can get my pics from the camera to my computer
1/4/2009 4:07:23 AM • Samsung Digimax... • Answered on Jan 04, 2009
Wont install on vista
try getting the latest driver... drivers have to be signed by windows in order to be installed in vista...
11/9/2008 7:04:50 AM • Samsung Digimax... • Answered on Nov 09, 2008
SAMSUNG 350SE PROBLEMS
THERE ARE A COUPLE OF WAYS TO GO ABOUT THIS PROBLEM. THERE ARE SOME PHOTO PROGRAMS THAT ARE PRETTY GOOD AT RECOGNIZING CAMERAS TO DOWNLOAD YOUR PICTURES. THEY ARE WINDOWS PHOTO GALLERY AND GOOGLES PICASA YOU DO HAVE THE PROPER CABLE TO CONNECT YOUR CAMERA TO A USB PORT ON YOUR COMPUTER? THAT'S A MUST. OK, ABOUT THE SOFTWARE. TRY GOING ONLINE TO THE SAMSUNG SITE AND ENTER 350SE AND SEE IF THEY DON'T HAVE THE SOFTWARE YOU NEED ONLINE THAT YOU CAN DOWNLOAD. MOST CAMERA MAKERS HAVE THERE SOFTWARE ONLINE. WINDOWS XP AND VISTA HAVE QUITE A LOT OF CAMERA SOFTWARE PRE INSTALLED. YOU MIGHT TRY SHUTTING DOWN YOUR COMPUTER, THEN CONNECTING YOUR CAMERA AND THEN BOOTING YOUR COMPUTER AGAIN AND SEE IF YOUR COMPUTER RECOGNIZES YOUR CAMERA. IT'S A CHANCE WORTH THE TIME. HOPE THIS HAS GIVEN YOU SOME IDEAS. NEED MORE HELP, REPLY TO: ARCLIGHT1217
11/8/2008 7:44:40 AM • Samsung Digimax... • Answered on Nov 08, 2008
Can't install software for D53 on my new Vista PC
There is no driver available for Vista for this camera
Here is link to all the software for the camera
If you are taking pictures off of a memory card, you can use a card reader and work with the pictures that way.
7/12/2008 4:17:15 PM • Samsung Digimax... • Answered on Jul 12, 2008
Drivers for vista
Try these drivers, it worked for a friends vista and digimax 350:
http://www.samsungcamera.com/uk/popup/download.asp?prol_uid=257&prj_uid=89
12/10/2007 6:24:19 AM • Samsung Digimax... • Answered on Dec 10, 2007
Images are to bright even after reset
This can be a broken shutter cable inside the lens. Toes it still make the "click" (not from the speaker)?
3/16/2015 11:44:14 PM • Samsung DigiMax... • Answered on Mar 16, 2015
How do I use the focus
be sure your lense and autofocus sensors are clean first thing.. then push the take picture button half way and it will autofocus. Pressing hte take picture button fully then will snap the picture.
1/3/2015 4:07:56 AM • Samsung DigiMax... • Answered on Jan 03, 2015
How do I get camera to recognise new card. It asks to configure,I press ok, it tells me to check card.It only goes in one way.How do I fix?
If you have a computer, insert it into the card reader,l select it and format with your computer
12/28/2014 3:20:00 AM • Samsung DigiMax... • Answered on Dec 28, 2014
What is the card type which can be inserted in Samsung Digimax 401
The 401 takes MMC and SD cards, 2GB or smaller.
10/6/2014 2:48:17 PM • Samsung DigiMax... • Answered on Oct 06, 2014
How to use a camera?
You should be able to follow the instruction available at this website. http://downloadcenter.samsung.com/content/UM/201301/20130129135843169/WB30F_English.pdf
7/31/2014 12:11:24 PM • Samsung DigiMax... • Answered on Jul 31, 2014
Samsung wb500 drivers windows xp
You need to install Intelli-Studio, Please view the following guide how to start this installation. http://skp.samsungcsportal.com/integrated/popup/FaqDetailPopup3.jsp?cdsite=uk&seq=1038212 Or download Intelli-Studio here: http://samsung-intelli-studio.updatestar.com/
5/25/2014 3:45:27 PM • Samsung DigiMax... • Answered on May 25, 2014
Samsung Digimax 350SE Digital Camera Logo
Popular Tags
16 questions posted
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
DigiMax Samsung
  • DigiMax Samsung
Most Popular Question
samsung 350se problems
  • Cameras
