20 Most Recent
Samsung Digimax V800 Digital Camera Questions & Answers
Does any 2.5 lcd samsung screen fit a Samsung V800 camera
Sorry, but for every camera, even from the same brand, they make special screens. In one brand, only when the housing of two camera's are the same you could have a chance the displays are the same. But even then you can't have any warranty on that, because they could look the same, but could have different resolution, making it impossible to exchange then from one to an other camera.
I have windows 8 on my laptop and it doesn't seem to be compatible with my Samsung digimax v800. is there a way round this?
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
My sd card wont fit anymore
be more clear ....how come it doesn't fit ...maybe it is fitting but not work ??I don't thing it is possible to not fit in the same spot ...if it doesn't work ..see that it has a locking device on it ...its just a little slide button on the side...
also look carefully maybe its damaged physically...or maybe the slot has something inside...like a strange object or so .... .....or you just used another card...or if now seams smaller...it used to have an adapter for it ...
I have a Samsung
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.The camera does not charge the battery through the USB port. You have to use the supplied battery charger or an equivalent unit.
Is there a firmware update
No. The differences between SD and SDHC goes beyond what firmware can change. It's possible to design a device to use both SD and SDHC cards, but a device that was only designed for SD cards cannot use SDHC cards without hardware changes.
Lost my disc and cant
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.
What capacity SD card can
The manual only guarantees cards up to 1GB. However, SD cards go up to 2GB and such cards should work. Cards larger than 2GB are SDHC and will NOT work.
Despite installing software on computer.when i
Picasa.
How do i change my aperture setting on my samsung
Turn the mode dial to "A". Turn the jog dial to change the aperture and the camera will change the shutter speed to match. You can also go to the manual mode, where you have to set both the aperture and shutter speed.Full details are in the "How to use the APERTURE PRIORITY mode" section of the manual (page 22 in my copy). If you need a copy of the manual, you may download one
here.
Vista drivers
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
Installer disc for samsung digimax V800
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as
Picasa.
SAMSUNG V800 SDHC CARD FIRMWARE UPGRADE
Wont install on my computer
Consider NOT using a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
Mac
That depends on what you want to do with the pictures. For basic cataloging and organizing, iPhoto comes with the Mac. Adobe Photoshop is the gold standard for photo editing (and costs a pocketful of gold). Photoshop Elements is a much less expensive alternative. Either Apple Aperture or Adobe Lightroom form a nice bridge between basic cataloging and heavy-duty editing. It all depends on what you want to do, and how you want to do it.
