20 Most Recent
Samsung Digimax A5 Digital Camera Questions & Answers
How do I get the date photo taken to appear on
choose to display the date from the manu...it does have a feature that allow this ...probably called time and date on the menu ...and inside has teh option to display on the picture...
anyway by default almost all display data on the name of the file on download..if you want just to keep track of them ...
LCD is showing wierd colours and patterns
Sounds like you have damaged the LCD. The LCD is made of 2 sheets of glass and then there is a liquid between the sheets that carry light. Sometimes the glass can crack and the liquid will leak or bleed and then the unit needs a replacement LCD. An impact can crack the glass, dropping it or freezing the unit. A damaged LCD is common because they are so small and thin you cant push on them.
A used LCD runs about $40. labor may be a bit more if this is the problem. People buy broken cameras on e-bay it maybe cheaper to get a different unit. If its under warantee you may be able to sxchange it.
On the bottom of your camera there is an A/V port you can hook the unit to a tv. To verify the screen is damaged hook it to a tv and see if you can see an image on the tv in record or review mode and see if the LCD and the tv view are the same. You could still use it if the LCD is damaged but you will need another way to view the menu. I have done this
How do I use the focus
be sure your lense and autofocus sensors are clean first thing.. then push the take picture button half way and it will autofocus. Pressing hte take picture button fully then will snap the picture.
Usb usb data transfer cable
Have you considered NOT connecting your camera to your computer?The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
http://picasa.google.com ).
How to use self timer Canon 2000 IS
I'm assuming you mean the IXY 2000 IS.Press cursor-down (marked with a one-handed clock) to bring up the shutter release menu, then use cursor-up/down to select the desired self-timer mode. Start the self-timer by pressing the shutter release button as usual.The IXY 2000 IS is called the SD950 IS in some parts of the world. You may download the SD950 IS manual
from here. The self-timer instructions begin on page 73.
Can i install samsung d760 to windows xp?
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
