20 Most Recent Tivo Series 2 Remote Control Questions & Answers
Sansui HDLCD2612 remote codes
These are the codes to check. 10463, 10171
1/31/2013 5:44:14 PM • Tivo Series 2... • Answered on Jan 31, 2013
Programming my TiVo remote to control my Proview TV
  1. Cover the end of the TiVo remote control with your hand.
  2. Hold down the TiVo and TV POWER buttons simultaneously until the red light on the remote control remains on.
  3. Remove your hand from the end of the TiVo remote control.
  4. Enter code 0999.
After you enter the code, the red light will flash three times and then remain on.
  1. Press CHANNEL UP once every two seconds. This will test hundreds of codes, one by one.
IMPORTANT: Do not go any faster than this or you may skip over a code that works.
  1. If you press CHANNEL UP and your TV turns off, press ENTER to select the code. Press the TV POWER button to test the code. If your TV turns on, you have successfully programmed the remote
11/27/2011 3:38:08 PM • Tivo Series 2... • Answered on Nov 27, 2011
My Virgin Media Tivo Remote is not working with my
Hello,Since you haven't mentioned the EXACT model of your remote, I can't exactly tell you the instructions. BUT you may choose your EXACT remote and refer to the instruction / codes from this link:Virgin Media RemotesI hope this helped you.You can rate my answer if you appreciate my help.Thanks!-damneddle
10/14/2011 5:37:33 PM • Tivo Series 2... • Answered on Oct 14, 2011
2answers
The channel guide shows No information available
Sounds like the guide needs to be updated. Look for info button or reset.
8/10/2022 8:22:50 PM • Tivo Televison &... • Answered on Aug 10, 2022
TiVo remote 2AA batteries one drains the other remains nearly full remote will not function why
Faulty batteries. Try Duracell Optimum, or Energizer Lithium.
3/4/2022 4:13:07 PM • Tivo Televison &... • Answered on Mar 04, 2022
Can anyone help me pair my Virgin Media TiVo remote to my Seiki Se43fo02uk TV please?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. https://homenol.blogspot.com/ https://remotesearch.blogspot.com/ https://electronicshelponline.blogspot.com/ https://electrohelponline.blogspot.com/.
11/14/2019 1:29:18 PM • Tivo Televison &... • Answered on Nov 14, 2019
2answers
I am trying to get a code for my nakamichi NK6 soundbar. I am using a tivo remote and the codes that came with it won't work.
0180,0194,0155 are the common codes to check with Nakamichi devices. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
9/13/2019 8:33:18 PM • Tivo Televison &... • Answered on Sep 13, 2019
2answers
My volume wont turn up or down with my tivo remote i have paired it a million times trying to get it to work but it wont had this problem befor and a tech guy came and pushed 2or 3 buttons and it started working does anyone know what those buttons are?
Hi Kelly, call the technician and ask him Indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution I wait your answer Greetings Franco Dosil Hola Kelly, llame al tecnico y preguntele Indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible Espero tu respuesta Saludos Franco Dosil
9/8/2019 2:06:32 PM • Tivo Televison &... • Answered on Sep 08, 2019
Accidently turned on closed caption. How do we remove it on LD TV with Suddenlink cable with TiVo remote?
your remote should have a menu button. go there and click through options
3/15/2019 1:21:37 AM • Tivo Televison &... • Answered on Mar 15, 2019
Televison & Video Logo
9 questions posted
Top Tivo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Tivo Televison & Video
Most Popular Question
programming tivo remote control proview
  • Televison & Video
