20 Most Recent Audiovox D1210 Portable DVD Player with Screen Questions & Answers
The DVD player has power
Reboot, reinsert the disc.
9/29/2017 6:52:24 PM • Audiovox D1210... • Answered on Sep 29, 2017
Why do i have a white screen on d1210 portable dvd player
That will be the screen driver chip faulty or even the luminance set too high. Try turning the brightness down and if there's a dark picture it's the chip, if not maybe even the flexi strip from the base to screen.
11/27/2014 2:18:34 AM • Audiovox D1210... • Answered on Nov 27, 2014
How do you open the unit?
Download the service manual to your set. It will have all details.
6/4/2012 5:25:50 AM • Audiovox D1210... • Answered on Jun 04, 2012
Sony LCD TV has Dark Picture
the problem is not the lamp.
This model has a set of two backlight lamps, and it is practically impossible that both lamps go faulty at the same time.
When the backlight lap in an LCD TV goes off in this way, the faulty part is always the backlight inverter, that is the high voltage board powering the lamp.
In your case you have to get the TV inverter booard replaced.
9/29/2011 4:11:11 PM • Audiovox D1210... • Answered on Sep 29, 2011
What kind of external antenna do you use and where
Hello
It is best to use a yagi antenna. It is highly directional, but if direction is in right way, it will give you best clarity picture. The signal strength will be greater than other type of antennas. OK.
5/22/2011 12:46:42 PM • Audiovox D1210... • Answered on May 22, 2011
Non remote menu scrolling
clean your remote rubber pad
4/6/2010 11:27:53 AM • Audiovox D1210... • Answered on Apr 06, 2010
Sony LCD kdl-40v2500
Take the backcover out test reconnect all the connections tightly.Or unplug a couples boards one at time u fine out which video board and replace that board.
8/13/2009 2:04:16 AM • Audiovox D1210... • Answered on Aug 13, 2009
Just a really dark screen on all functions
If you are still under warranty try calling audiovox customer support at this telephone number 1-800-645-4994. Give them the model number of you dvd player and tell them the problem you are having with the dark screen. If you are not under warranty, You can still call them and ask them where to get service for bad power inverter or a bad back light problem. If they cannot help you you can go to this website http://www.lcdparts.net/Default.aspx They do all kinds of LCD repairs and also have a technical help telephone number. 1-877-870-0581. Give them a call and tell them the name of your dvd player and the model number and see if they can help you get repair service for it. I hope this information will help you with your problem.
5/30/2009 4:26:06 AM • Audiovox D1210... • Answered on May 30, 2009
Audiovox portable dvd PVS6360 unlock codes
Audiovox code hack for DVD players
1. Turn the DVD player on
2. Go to the main setup page
3. In the main set up page press the numbers 9653
4. In the new menu go to region press enter
5. In region use the up and down arrow to select the region
6. Turn the DVD player off and turn it on
7. You now should have changed to the region of choice.
This hack was found on the internet. I hope this information helps you with your problem.
5/30/2009 4:09:18 AM • Audiovox D1210... • Answered on May 30, 2009
Audio yes, picture no!
You can try to reset the DVD player to factory setting. Go to the set up main page. Highlight preferences and press enter. Go to the defaults setting and press enter. This will reset the DVD player to the original factory settings. If this does not solve you problem you can call the Audiovox customer support telephone number. 1-800-645-4994 Give them the model number of your DVD player and tell them the problem you are having with it. They will be able to tell you how you can obtain service for your problem. I hope this information helps you with your problem.
5/30/2009 3:52:43 AM • Audiovox D1210... • Answered on May 30, 2009
Audiovox pvd80 region problem
Audiovox code hack For DVD player D1210
1. power on
2. SETUP
3. in setup digit 9653
4. go to new menu VERSION
5. in region use UP/DOWN to change region
6. power off and power on
7. Enjoy!!!
5/30/2009 3:44:43 AM • Audiovox D1210... • Answered on May 30, 2009
Screen wont light
Are you still under warranty with this product? Have you tried to reset the DVD Player to the factory settings. You can do this by opening up the menu and on the main page highlight preferences and press enter.Now go to the default setting and highlight it and press enter. This will reset the DVD player to the original settings.If this doe not solve your problem you can call Audiovox customer support at this telephone number. 1-800-645-4994. Give them the model number of you DVD player and tell them the problems you are having. They will be able to tell you how to get the unit serviced. I hope this information helps you with your problem.
5/30/2009 3:37:34 AM • Audiovox D1210... • Answered on May 30, 2009
Audiovox D1210 DVD won't load to play. When we put
Your DVD players may have slip out of calibration. You can try setting them back to factory specifications. To do this go to the set up menu main page. Highlight preferences and press enter.Next highlight defaults and press enter. This will reset the DVD player to the factory settings. This procedure is explained in the owners manual on page 26. If this does not solve your problem, you can try using a cleaning disc to clean the laser head and transport. This should restore the laser, and transport so that you can use it. If you are still experiencing problems with the DVD player, you can call Audiovox customer support at this telephone number. 1-800-645-4994. Give them the model number of you DVD player and tell them about the problem you are having with the DVD player. I hope this information helps you with your problem.
5/30/2009 3:22:00 AM • Audiovox D1210... • Answered on May 30, 2009
Audiovox d1210
We bought this player almost 5 years ago, and have the same problem. When we called audiovox at the time they told us that it was because some of the dvd mnufacturers had changed the format/technology in which they recorded the dvd programs. The biggest problem was with the Disney dvd's. Also, that they did not have any software upgrades at that time to upgrade the player. We used it for a while with the hit and miss movies that it would play, and then finally shelved it and bought a minivan with a preinstalled dvd player. Very rarely use the audiovox now. I am surprised; however, that after 5 years they would still have the same problem and have still not yet upgraded the software in this player. Good luck.
2/1/2008 8:02:34 PM • Audiovox D1210... • Answered on Feb 01, 2008
Blue light on antenna isn't turning on remote start won't work.
It's possible that the issue with your Audiovox pursuit PRO9056c remote start system is related to the antenna or its connection. Here are a few things you can try to troubleshoot the issue:
  1. Check the antenna connection: Make sure the antenna is properly connected to the control module of the remote start system. You may need to remove the panel where the antenna is mounted to access the wiring and connections. Check the wiring for any signs of damage or corrosion, and make sure the connections are tight.
  2. Check the fuse: The remote start system may have a fuse that is responsible for powering the antenna. Check the fuse to make sure it is not blown or damaged.
  3. Reset the system: Try resetting the remote start system by disconnecting the battery for a few minutes, then reconnecting it. This may help reset the system and resolve any issues that were causing it to malfunction.
  4. Consult a professional: If you are not familiar with automotive electronics or are unable to resolve the issue with the above steps, it may be best to consult with a professional technician who can diagnose and repair the system for you.
It's also possible that there is a problem with the remote start system itself, such as a malfunctioning control module
2/16/2023 10:58:50 PM • Audiovox... • Answered on Feb 16, 2023
I bought a HDMI to AV converter so I can use my Roku on my Audiovox KLV3913 TV, since there is no HDMI connection. I can't seem to get it to work!! Help!!!
Unfortunately, you are probably dealing with a copy protection issue. The digital handshake can't be returned by your KLV3913. You get the same issue if you connect a HDMI source (Blu-ray player) to a VGA monitor. I wish that I had better news for you. Cindy Wells
12/6/2022 5:27:22 PM • Audiovox... • Answered on Dec 06, 2022
2answers
I have an Audiovox VE927 under cabinet tv/dvd/radio combo. I have no sound. Is there a sound board in this unit that could go out?
It's all one board, chances are your audio output IC has failed and needs replacing
8/7/2022 6:55:56 AM • Audiovox... • Answered on Aug 07, 2022
Audiovox D1210 Portable DVD Player with Screen Logo
18 questions posted
Top Audiovox Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Audiovox Televison & Video
Most Popular Question
sony lcd tv dark picture
  • Televison & Video
