20 Most Recent
Audiovox AVT-1475 13" TV Questions & Answers
Where can buy a dc
Tries websites like Amazon.com,Ebay.com,Partstore.com to buy a new a/c power cord.
5/12/2011 9:30:51 PM •
Audiovox...
Answered
on May 12, 2011
TV AudiVox tv has
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board (also on circuit board that is fixed to CRT TUBE ) at some soldering joints crack develops....then due to loose contact picture becomes small in size ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
4/22/2011 9:18:51 PM •
Audiovox...
Answered
on Apr 22, 2011
Where can I get a 12v 4amp power supply
look on amazon web site if you have old power supply you can use model number on it
if not try the model number on the appliance
hope this helps MERRY CHRISTMAS
12/5/2009 5:28:22 PM •
Audiovox...
Answered
on Dec 05, 2009
No picture
If this is connected to a VHS or DVD player or roof antenna, when problem occurs Check to see that the video in to TV cable is tight. If so you my need a new cable
7/8/2009 12:37:05 AM •
Audiovox...
Answered
on Jul 08, 2009
Vertical hold on tv
no control over the remote..but impossible not to have vertical hold control in the TV itself. it should have one maybe at the back.
4/9/2009 7:03:05 PM •
Audiovox...
Answered
on Apr 09, 2009
Sound won't work
Most likely the audio output stage in the TV is blown!
You will have to bring the set in for service. Most likely they will have to change audio output IC and some support components.
Jerry G.
4/19/2008 11:37:20 PM •
Audiovox...
Answered
on Apr 19, 2008
Blue light on antenna isn't turning on remote start won't work.
It's possible that the issue with your Audiovox pursuit PRO9056c remote start system is related to the antenna or its connection. Here are a few things you can try to troubleshoot the issue:
- Check the antenna connection: Make sure the antenna is properly connected to the control module of the remote start system. You may need to remove the panel where the antenna is mounted to access the wiring and connections. Check the wiring for any signs of damage or corrosion, and make sure the connections are tight.
- Check the fuse: The remote start system may have a fuse that is responsible for powering the antenna. Check the fuse to make sure it is not blown or damaged.
- Reset the system: Try resetting the remote start system by disconnecting the battery for a few minutes, then reconnecting it. This may help reset the system and resolve any issues that were causing it to malfunction.
- Consult a professional: If you are not familiar with automotive electronics or are unable to resolve the issue with the above steps, it may be best to consult with a professional technician who can diagnose and repair the system for you.
It's also possible that there is a problem with the remote start system itself, such as a malfunctioning control module
2/16/2023 10:58:50 PM •
Audiovox...
Answered
on Feb 16, 2023
