20 Most Recent
Cobra 75 WX ST 40-Channels Handheld CB Radio Questions & Answers
Squelch doesn't work
I could tell you but in the end you have to take it to a tech anyway so have at it.
Cobra troubleshooting
These models have all connections going thru the mic cable. to the lil box.. if your getting supply voltage on the pins at the box.. check for a bad mic cord..
Can't pick up any talk on my cobra 75 ws xt cb radio
Was your antennae set up professionally? You may have a short in the cable or connections or even a bad antennae and/or a bad match. Was it matched with an SWR meter? Have these checked out because it does sound like an antennae or cable/connector issue.
When I press the PTT
hi 4fshin
you need to check if the cable connection is still fit
if not srengthen the cable and it should work
if the connection is still strong try to wire it to a new radio stasion and then check if it still doesnt work you need to buy a new one if its work you have a problem with the exit in your machie
I am to trasmitt and receive while ignition key is
Hi, my name is John. That noise you hear is probably coming from switch,such as ,seat belt warning,door,light, key switch , exc. Try running your CB wire strait to the battery, and see if it stops. If not, Radio Shack sells a noise limiter that goes in line with your connection, don't know how much. Do you have your noise limiter or noise blanker switch on the radio?...hope this was very helpful....
Cobra 75 wx st
no sound/speaker
Hi, my name is John. try putting a external speaker in back of radio and see what happens, might need to replace internal speaker, or something internal. Let me know, I will post the process here......Hope this was helpful..
When i try and get a radio check i get no
Well, first of all, it's your radio. The Cobra 75 is about the worst money you can spend. They transmit at about 3 watts and all of Jeep customers have opted for bigger radios and I have gotten them away from the handheld units and they appreciate it. The issue is your antenna, what kind is it, where is it mounted, has it been tuned? let me know.
Dodgem250.com
Cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
