20 Most Recent
Belkin (F5D8235-4) Wireless Router Questions & Answers
Cant reach 192.168.2.1 please help!!!!
Welcome to Fixya. Make sure that you are using a computer that is connected to the router using ethernet cable. If still fails you can reset the router by pressing the reset button at the back of the router for 5-10 seconds using a pen or paper clip and make sure that the router is on.
Thanks for using Fixya.
5/25/2022 3:17:36 AM •
Belkin...
Answered
on May 25, 2022
How do I retreive a lost password
connect your your pc or laptop with the router using the lan cable.open your browser bar and type 192.168.2.1 setup page addressgo to wireless security and change your passwor
11/18/2012 8:49:51 AM •
Belkin...
Answered
on Nov 18, 2012
Router now works intermittently, will disconnect
Try resetting the router. If it does not work then you will have to update the firmware of the router. To do that you have to download the firmware file of the router ( it will have an extension of .bin). Save the file in your pc and go to the router's page and update it. It will look for a .bin file. Browse to the location where you downloaded the firmware and update.
5/12/2012 8:19:00 PM •
Belkin...
Answered
on May 12, 2012
F5d8235
Seems like a router going bad for me since the problem doesn't happen when you directly connect to the modem. Try a router reset, however.Good luck
2/25/2012 5:45:50 AM •
Belkin...
Answered
on Feb 25, 2012
I had a linksys wireless router that worked fine
I have the same setup. My router is in the basement right below as well. Nothing works better than direct wiring... if you can, consider drilling a hole in the floor (near the wall) behind the TV and BluRay, and run an ethernet cord directly from the player to the router. Ethernet cables are cheap as dirt online, and not too bad at big stores like Home Depot.
5/5/2011 4:03:34 PM •
Belkin...
Answered
on May 05, 2011
Lost connection to wireless router.
HERE is the link directly from Belkin for the drivers to your wireless router. The only information you will need to put in to get the correct driver is the version number. There is a link on that same page to tell you how to find the version number.In box 1 select "N" In box 2 select F5D8235, then in box 3 select your version number.
4/27/2011 1:29:51 AM •
Belkin...
Answered
on Apr 27, 2011
I have my router setup hardwired to my desktop and
on your browser. got 192.168.1.1
username = admin
password = password
then enable Broadcast SSID. This is the name of your wireless connection. You can name it anything.
You can also put WEP password to prevent others to connect to it.
tell your son to scan for network access again, then chose the name of the wireless connection you chose with the password.
Hope this helped you
4/9/2011 6:32:20 AM •
Belkin...
Answered
on Apr 09, 2011
My wired computers have internet
Here is a link to a list of default router IP's, match the brand on your router to one on the list, and type the IP address into your internet explorer (or other web browser) address bar, login with your details (default or personal) and check your wireless settings for activity or problems. Alternately try unplugging power from your router for 5 seconds and plugging it back in to reset it (do not use the reset button on the back of the router)
3/15/2011 11:30:45 PM •
Belkin...
Answered
on Mar 15, 2011
Mtv music generator detecting directx 7
ok... so I've now installed this on my new pc that i built... first in order to get it to install at all you must download DirectX 7.0 and right click to "--(edit compatibility settings to windows 98/Me and run as administrator)--" remember this as well be doing it a few times. once you do that install DirectX 7.0 and say yes to all. now that this is installed take the .iso file you have and burn it to a cd or DVD-r, once burned you need to go to my computer and right click on the cd/DVD drive, select open (NOT open autoplay), inside the disc menu i want you to go to 2 files... "setup" and "start" need to also have their compatibility settings changed to the above settings. now that these are set stay in the cd menu and double click "setup" this will take you through the setup procedure. after the setup procedure is finished do not view the notes, and continue back to the desktop. now from your start menu load the game and it should run
