20 Most Recent
Samsung RS277AC (27 cu. ft.) Side by Side Refrigerator Questions & Answers
How to turn on ice maker
On the WEB
www.manualslib.com > ... > Samsung Manuals > Refrigerator > RS275
View and Download Samsung RS275 owner's manual and installation online. SamsungSide By Side Refrigerator Owner's Manual. RS275 Refrigerator pdf ...
Display panel not working
Dear ramarsden,Do not try to replace the panel by yourself. Call the nearest service point and tell them to send a technician over to your house. The Display panel must be broken. They are generally designed to be long lasting.
Samsung RS277ACPN/XAA Freezer fan not working?
hi david.this is difficult without a visual and test but make sure the door button is pressed on when checking.if it doesnt have one then i would think is the pcb.ice dispenser would be a seperate issue unless connected to pcb. good luck Ali
Hi I have a Samsung fridge model DA99-01221D . My freezer is cooling well but fridge is not cooling at all please help
Check the Control Settings:
Ensure that the temperature settings for both the fridge and freezer compartments are appropriately configured. Sometimes incorrect settings can lead to cooling problems.
Make sure the fridge is not in demo mode. If it is, disable demo mode by referring to your user manual.
Inspect the Door Seals:
Damaged or worn-out door seals can cause cold air to leak out, resulting in insufficient cooling in the fridge compartment. Inspect the door seals for any cracks, tears, or gaps.
If you find any issues, consider replacing the door seals.
Evaporator Coil and Fan Check:
The evaporator coils in the fridge play a crucial role in cooling. If they are frozen or malfunctioning, it can affect cooling.
Similarly, check if the fan responsible for distributing cold air inside the fridge is working correctly.
Reset the Refrigerator:
Sometimes a simple reset can resolve cooling issues. Unplug the fridge from the power source for a few minutes, then plug it back in.
Observe if there's any improvement in cooling after the reset.
Compressor Overheating:
You mentioned that the compressor is very hot. An overheated compressor can impact cooling.
Allow the compressor to cool down completely before switching the fridge back on.
4/1/2024 3:42:13 PM •
Samsung...
Answered
on Apr 01, 2024
Fans in both refrigerator and freezer of Samsung RF4287 HARS-xaa are not working. Replaced evaporator fan motor in fridge and it is still not working. Help, please!
could be just the coil on the valve, but most more likely valve getting stuck as it opens. somtimes can take apart and clean, will work for awhile, but if have the cash best just swap it out. will save you hassel down the road.My Aplogies I was under the impression you had already located the valve. I as I have not seen unit I can not give the location, However since it is on the water system, I would trace water tubing from where it connects to unit. It should not be far from inlet connection. Look for tubing going to a valve with wires ontop, ensure after the valve is where you whish water/ice to come out. Once that is located take photo and order new valve, or secure water remove and clean valve. Note have container ready as water will leak once you remove valve.
1/25/2024 4:41:01 PM •
Samsung...
Answered
on Jan 25, 2024
Our Samsung refrigerator model RFG297ACRS is not cooling and freezer not cold.
First I would clean all grim. Second if you do not have refrigerant gauges feel discharge line with hand. Will be a smaller line and coverd with foam. It should be hot to condensor. if not You probabaly lost charge. Also top of compressor should be hot. Should the above not meet specs. You need to find leak, get a pro. to locate repair leak, as you need licenese to go further.
1/24/2024 9:51:02 PM •
Samsung...
Answered
on Jan 24, 2024
Evaporator fan new but not working on samsung rs267lash
Manny MANY unfortunate customers who bought this **** from Samsung have problem.
Specifically the Freezer cold but fridge side no lower than 55deg problem.
It is a known defect that Samsung has not taken ownership
of.
I have the same problem with the same model as many.. if you search the
net.
Iv'e been trying to find a designated website for repairs for this
problem. Please post website with solution if anyone finds it.
Thanks
1/24/2024 8:45:56 PM •
Samsung...
Answered
on Jan 24, 2024
Samsung fridge freezer not freezing properly
First: i don't know. In the manual there should be some pages for solving dysfunction and what the lights mean.
Always check for damage on the closed and pressurized system, including inside, where the tubular radiators are, mostly half within the panels. Those may have broken when using tools to remove ice or been hit rough with some object.
For a right understanding: the fridge must not be shaken or tilted and carried. When this has happened, then the evaporation fluid or refrigerant can be mixed with the oil that resides on the bottom of the compressor. It may only have a small sponge to clear the fluid from a little oil contamination. What finally solves the mixing is shutting the fridge off for 24 hours and when not completely satisfied with the result, immediately for another 24 hours.
Another thought is that a fridge may not function at all, in a cold room. Transfer of heat is totally not the same at all temperatures. Many people have been the same disappointed as you, thinking they can find a cold place for the fridge or freezer. So, when this has happened when the room temperature dropped dramatically, get it out of the cold or shut it down because it performs at its maximum capacity. That is where my bet is at.
The radiator at the back can also not function right when it is close the wall and/or an object is placed right above it. The heat must be dispersed. Best of luck
11/20/2023 5:46:53 AM •
Samsung...
Answered
on Nov 20, 2023
Samsung refrigerator display RD code. How to fix please.
Question edited for a lot more clarity. Please proof read before Posting..
Question moved from Cellphones category. 40,000 to choose from
RD is air damper iced up fault. The damper in the freezer spins around to close/open the air from the freezer to the fridge. It ices up from time to time, or the damper motor, or sensor that reads it's position fails.
Apr 27, 2010
If you can spell it, you can Google it! Lots more in the link. 'make model (what it is)' in all questions please.
https://www.google.com/search?q=Samsung+refrigerator+RD+code
10/22/2023 5:53:54 AM •
Samsung...
Answered
on Oct 22, 2023
