20 Most Recent Insignia NS-LCD32 LCD TV Questions & Answers
How do you hook up cable box using coaxial in hdmi out
If your cable box has an HDMI OUT connector you simply connect the HDMI cable to the TV and the coaxial cable from the cable company to the coaxial input on the cable box. Then select the HDMI input on the TV that matches the number of the HDMI input port you chose on the back of the TV.
10/4/2016 1:17:47 AM • Insignia... • Answered on Oct 04, 2016
Where is the location of T CON board on NS LCD32
Cheryl, I will post links to what the T con board looks like so when you remove the rear panel from TV, you will be able to compare and find it easily. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace... INSIGNIA NS LCD32 Con Board LC320W01 SLA1 6870C 0142B 2L Amazon com INSIGNIA NS LCD32 CON BOARD CPT 320WF01C SD Electronics
3/23/2016 5:08:58 PM • Insignia... • Answered on Mar 23, 2016
Burnt wire on harness going up to the back light, looking for repair manual so i can rewire.
Even you get its repair manual; you can't wire it. Do you think you can?
9/29/2015 9:54:08 AM • Insignia... • Answered on Sep 29, 2015
How can I reset my insignia tv #NS-LCD32 to global volume unlock with a RCA universal remote
Try this solution by another user:
timyorba 1 solutions Jul 21, 2011 So, For anybody who doesn't know yet, you do not need the factory remote to restore button functions to your Insignia IS-LCDTV26. All you need to do is program a universal remote that can power on and off the TV, then"**press the "MUTE" Button 10 times successively**"and Voila! Unlocked, you should see the status appear in the corner of the TV if everything worked, if not try another tv code or try the manual search function on the remote to find another compatible code set.
12/26/2012 7:08:03 PM • Insignia... • Answered on Dec 26, 2012
Need to setup my tv #NS-LCD32 have no remote
You are going to need an original remote for that set.
12/20/2012 1:49:12 PM • Insignia... • Answered on Dec 20, 2012
Color separation ~ Insignia 32" NS-LCD32
1. Unplug unit from wall for 3 minutes;2. Press & hold Power button for 1 minute;3. Plug in unit. OR: 1. Unplug for 3 minutes.2. Plug in unit.3. HOLD Power Button as unit starts ... hold until the unit flickers on then off twice. This effectively returns the components to factory specs, much like resetting a computer. It offers a *temporary* fix, lasting 45 minutes to hours. All depends on the unit.Mom has an Insignia 32" with the same color separation problem, which worsens as the day progresses. Best results achieved while television is cold. Dust in the unit could contribute to the problem ... try to keep the unit dust free as possible.
11/15/2012 2:01:35 PM • Insignia... • Answered on Nov 15, 2012
The sound will not come on
See previous answer I gave to you for this issue.
10/30/2012 2:26:41 AM • Insignia... • Answered on Oct 30, 2012
No sound
Check the usual things:In menu speakers not switched off.Set not set to external speakers if equipped.Does the set have sound when a DVD connected to a rear input is used?
10/30/2012 2:26:12 AM • Insignia... • Answered on Oct 30, 2012
Insignia ns-lcd32 has developed a vertical shadow.
Unfortuntly you have a panel that is going out. This is not cost effective to fix.
4/11/2012 12:14:38 PM • Insignia... • Answered on Apr 11, 2012
Insignia NS-LCD32
Most likely either the main board (processes all signal) or even an issue with the power board (supplies wrong voltage somewhere).In either case not cheap.
3/23/2012 4:54:27 PM • Insignia... • Answered on Mar 23, 2012
Screen black. Audio works. Not
Good day!!! That problemisusually cause of bad inverter board that responsible for the back light...Please try to replace it to end this issue... Thanks for using fixya..
9/13/2011 3:14:36 AM • Insignia... • Answered on Sep 13, 2011
My tv starts on at least the green button goes on,
Insignia are a low-end Best Buy brand, and as such their reliability is poor.
If you're plugged in, the inputs are set correctly and the power comes on on the TV but you receive no picture, there is an issue with the TV itself.
Insignia offers a 2-year warranty, but you must have the original box and must be willing to pay for shipping. If you lack the original box or your purchase was longer than 30 days ago and you didn't purchase the extended warranty from Best Buy, you're most likely going to need a new TV, as they cost more to repair than they're worth.
4/15/2011 8:55:28 AM • Insignia... • Answered on Apr 15, 2011
No sound, no picture, it states no signal.
You can just buy a new remote. Test it using the smartphone front camera trick. Or it is the television that has no signal, do a Power Reset. Pull the mains plug for 5 minutes. Press and hold the power button on the set for 1 minute. Plug back in. Also check the input leads on the back for whatever is supplying the signal, Cable, Satellite, OTA, then check the Source button on the remote.
Insignia LCD TV Remote Control - NS-RC01G-09
Amazon.com https://www.amazon.com > product-reviews Find helpful customer reviews and review ratings for Insignia LCD TV Remote Control - NS-RC01G-09 at Amazon.com. Read honest and unbiased product reviews ...
INSIGNIA NS-RC01G-09 Remote Control
RemoteControls.com https://www.remotecontrols.com > product Price: $9.99 FREE SHIPPING - ALL US REMOTES ... Shipping - We receive hundreds of orders a day at RemoteControls.com. We do our best to ship them the same day you ... US$9.99
Insignia NS-RC01G09 Instruction Manual
ManualsLib https://www.manualslib.com > ... > NS-RC01G09 View and Download Insignia NS-RC01G09 instruction manual online. NS-RC01G09 remote control pdf manual download.
Replacement Remote Control for INSIGNIA NS-RC01G-09 ...
Amazon.com https://www.amazon.com > Replacement-INSIGNIA-N... Buy Replacement Remote Control for INSIGNIA NS-RC01G-09 NS-P501Q-10A NS-L42Q-10A LED HDTV TV: Electronics - Amazon.com ? FREE DELIVERY possible on eligible ... US$32.99 · ‎ In stock ..
1/23/2024 7:31:36 PM • Insignia... • Answered on Jan 23, 2024
How do I make my lodging star universal remote? Go to channel scan on my insignia t v
You did not provide proper make and model of remote and TV. Try this manual for properly program your TV URC105_Manual.pdf
1/19/2024 11:26:16 AM • Insignia... • Answered on Jan 19, 2024
Directions on how to program Welby remote to insignia tv
You did not mention the model of remote and tv. Anyway I am sharing following two links for your help. Big-Button-Manual.pdf (magnifyingaids.com) Oversized Key Remote Programming Guide - ValuNet Fiber Internet, TV & Phone ' Emporia Kansas (myvalunet.com)
1/5/2024 12:27:31 PM • Insignia... • Answered on Jan 05, 2024
Insignia NS-LCD32 LCD TV Logo
25 questions posted
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Televison & Video
Most Popular Question
location t con board ns lcd32
  • Televison & Video
