20 Most Recent Furuno 1833C/NT GPS Receiver Questions & Answers
Try adjusting the GPS position offset in the GPS Sensor Settings Menu.
Furuno 1833C/NT... | Answered on Nov 18, 2013
I know this is an old question but just ran across it. The 1833C/NT is a radar and chart plotter. It requires the external and optional black box sounder to have depth recorder functionality.
You have to be in the "Installation Mode" to adjust the heading. Hold menu key down while pressing the "pwr" key. Then select menu/installation and you'll be able to find the heading adjustment section.
Furuno 1833C/NT... | Answered on Jul 15, 2010
the GP31 has an NMEA in/out in the power cord - out is yellow green in blue(or black) and white on the 1833 you will use data 4 typically which has an in and out also, same colors hook out to in and in to out, program and done
Furuno 1833C/NT... | Answered on Jan 16, 2010
The display uses a serial interface, otherwise known as a comm port. You can get a USB to DB9 adaptor practically anywhere. Once you have a serial connection, you will need software such as MaxSea to send the waypoint with.
Furuno 1833C/NT... | Answered on Jan 13, 2010
AT A STORE THAT SELLS BATTERIES
Furuno GPS | Answered on May 01, 2019
Possibly voltage too low, faulty unit, no power coming to the unit.
Furuno GPS | Answered on Oct 09, 2018
The GP31 manual doesn't mention language change
Furuno GP 31 Operator Manual
whereas the GP33 does
Furuno GP 33 User Manual Language Setting Input output Data
Try doing a Factory Reset and see if you are offered language at first Start Up?
https://www.manualslib.com/manual/256035/Furuno-Gp-33.html?page=68&term=reset&selected=4
There is a Foruno Forum
Furuno USA Community View topic Wiring Help GP 31 FCV 620
Furuno GPS | Answered on Feb 11, 2018
GPS Logo
5 questions posted
Top Furuno GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Furuno GPS Expert? Answer questions, earn points and help others
View Most Popular
Furuno GPS
  • Furuno GPS
Most Popular Question
when turn unit will not read depth
  • GPS
