20 Most Recent Samsung HT-Z 120 T Theater System Questions & Answers
How do I connect my YAMAHA RX-V493 audio/video receiver to my Samsung UN65HU8550F TV?
On the rear of your TV connect, with a phono/RCA cable to the Audio R + L sockets, connect the other ends to your Yamaha using the TV in sockets. See photos attached screenshot 2024-04-05 at 20.45.20-undefined-undefined-0.png screenshot 2024-04-05 at 20.43.54-undefined-undefined-1.png Hope that helps. HDMI is for video unless the extra pins are added for audio.
4/5/2024 7:49:49 PM • Samsung Audio... • Answered on Apr 05, 2024
How to fix my samsung YP-U4 mp3 no screen display
See page no 65 troubleshooting in user manual YPU4J-CANADA-ENGLISH0.0_0610.indd (samsung.com)
1/10/2024 12:18:19 PM • Samsung Audio... • Answered on Jan 10, 2024
Frozen screen on my old samsung yp-tyj mp3 player.
See following link, it may resolve your issue My MP3 Player Is Locked Up (Frozen). ' Samsung Africa
12/28/2023 12:46:59 PM • Samsung Audio... • Answered on Dec 28, 2023
Pairing Samsung remote to Yamaha RX-V361
Normally makers don't play ball between each other. Yes if it was a Samsung Television and a Samsung Receiver A/V System. Or if you have something like a Cable Box or Satellite System that is made to interact with other makes. Or if it is a Universal Remote. I think you were just lucky that it happened to use the same frequency. Look in the manual for a scan command. https://www.google.com/search?q=Connect+Samsung+OLED+S90+remote+to+Yamaha+RX-V361+via+optical ..
12/20/2023 12:35:03 AM • Samsung Audio... • Answered on Dec 20, 2023
My Samsung yp-s3 won't open without connecting to the power supply or power bank
Check the battery. It may require replacement.
12/19/2023 2:02:55 PM • Samsung Audio... • Answered on Dec 19, 2023
Is it compatible with other phones apart from the iPod?
You would have to define 'it'. In a question talking about two items, you need to clearly state 'make model (what it is)' for both items. The main item should be the first 3 words in the question. ..
9/12/2023 6:01:10 PM • Samsung Audio... • Answered on Sep 12, 2023
2answers
Hi, I'm using the Samsung HT-E330K. It works but does not speak out. The power display is fine but no sound
If your Samsung HT-E330K home theater system is not producing any sound even though the power display seems to be working fine, there are several potential causes and troubleshooting steps you can try: 1. **Check Volume Levels:** Make sure the volume on the home theater system and the connected TV (if applicable) is turned up and not muted. 2. **Check Audio Source:** Verify that the correct audio source is selected on the home theater system. If you're using multiple input sources (DVD, TV, AUX, etc.), make sure the right input source is selected. 3. **Audio Cables:** Ensure that all audio cables are securely connected to both the home theater system and the audio source (TV, DVD player, etc.). Sometimes, loose or faulty cables can result in no sound. 4. **Speaker Connections:** Check that all speakers are properly connected to the home theater system and that the speaker wires are securely inserted into the appropriate terminals. 5. **Audio Settings:** Go through the audio settings on both the home theater system and the connected TV (if applicable). Ensure that the correct audio output settings are configured. 6. **Mute Function:** Double-check that the mute function on the remote control or the home theater system itself is not engaged. 7. **Speaker Balance:** Check the speaker balance settings to ensure that sound is not unintentionally directed to one side or speaker. 8. **Reset to Default Settings:** If you've made any changes to the settings recently, consider performing a factory reset to revert to the default settings. 9. **Firmware Update:** If there is a firmware update available for your home theater system, consider updating the firmware as it might resolve any software-related issues. 10. **Test with Different Source:** Test the home theater system with different audio sources to rule out issues with a particular device. 11. **Test Speakers:** If possible, disconnect each speaker one at a time and test the audio to identify if a particular speaker or speaker wire is causing the issue. 12. **Check Speaker Impedance:** Ensure that the speakers' impedance matches the specifications of the home theater system. Mismatched impedance can affect sound quality. 13. **Contact Support:** If you've tried these steps and still have no sound, consider contacting Samsung customer support or seeking assistance from a professional technician for further troubleshooting and repair. Remember to refer to your device's user manual for specific instructions related to your model.
8/29/2023 9:05:03 PM • Samsung Audio... • Answered on Aug 29, 2023
2answers
Part is missing pls help me what part number of this transistor this is from samsung home theater HT-330K thanks in advance
Service Manual. Page 5.2
SAMSUNG HT-E330K Service Manual download, schematics ...
elektrotanya.com > download
Translate this page Download SAMSUNG HT-E330K service manual & repair info for electronics experts.
Home Entertainment System HT-E330K ' Samsung Support ...
www.samsung.com > ... > Standard home cinema system
Mar 18, 2020 - Home Entertainment System HT-E330K. Solutions & Tips, Download Manual, Contact Us. Samsung Support Singapore. Missing: schematic ‎' Must include: schematic
8/26/2023 9:36:43 AM • Samsung Audio... • Answered on Aug 26, 2023
I have a vintage Samsung midi hifi 7450 used daily. But the record deck has suddenly stopped turning.
The platter drive belt needs replacing. Platters normally lift off, sometimes there is a c-clip.https://www.google.com/search?q=samsung+midi+hifi+7450+drive+belt+replacement..
8/11/2023 4:34:35 PM • Samsung Audio... • Answered on Aug 11, 2023
Why does the volume on my tv change up or down when I change channels
I believe that everyone experiences this. It is done by the network on purpose. I believe that there is a setting in most tv's to adjust the volume so that it doesn't happen. Every TV is different though but it is worth a look.
8/8/2023 8:46:21 PM • Samsung Audio... • Answered on Aug 08, 2023
Transfer music from samsung to PY-P2
Samsung .... model. PY-P2 ..... is what .
8/2/2023 4:04:25 PM • Samsung Audio... • Answered on Aug 02, 2023
Sind die Fragen kostenlos
ENGLISH: Are the questions free?My samsung yh-925 gs - the display says 'Repair Firmware'.Es ist KOSTENLOS, Fragen zu stellen.Sie erhalten die Antworten KOSTENLOS!Aber..... wir sind eine nordamerikanische Website und sprechen Englisch. Benutzen Sie Google Translate wie ich!https://www.samsung.com/ca/support/model/YH-925GS/XAC/And Recovery Utilityhttps://www.manualowl.com/m/Samsung/YH925GS/Manual/48787?page=10..
7/13/2023 3:04:58 PM • Samsung Audio... • Answered on Jul 13, 2023
How can I connect wireless headphones to my Samsung 55 TV UN55FH6003F that has no audio outputs?
I don't know if the OS on the UN55FH6003F will work with a USB bluetooth adapter; it would depend on if it can find the driver. A Bluetooth audio transmitter is more likely to work. This is one example: https://www.amazon.com/Bluetooth-Transmitter-Wireless-Headphone-Speaker/dp/B0838YPSZT/ref=sr_1_3?keywords=bluetooth+transmitter+optical+input&qid=1686438206&sr=8-3 . This model comes with various audio cables and a power supply. I hope this helps. Cindy Wells
6/10/2023 11:07:28 PM • Samsung Audio... • Answered on Jun 10, 2023
2answers
Speakers L & R for Samsung TV UA40D6600
I would try searching on Amazon for speakers for your TV or on Samsung's official website for speakers and electronics.
5/8/2023 4:14:43 PM • Samsung Audio... • Answered on May 08, 2023
Samsung HT-Z 120 T Theater System Logo
Popular Tags
4 questions posted
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Audio Players & Recorders
Most Popular Question
replace kf8n60f 8n60c mosfet
  • Audio Players & Recorders
