20 Most Recent GE 31GT659 31" TV Questions & Answers
0answers
GE 31GT659 31 Picture on right is vertically drooping
Check the degaussing posistor. Replace it. It can be located at the main power regulator section. Will look like this.7_30_2012_4_10_53_pm.jpg
7/30/2012 4:10:59 PM • GE 31GT659 31"... • Answered on Jul 30, 2012
Picture shrinkage on sides
Possible that the power supply has issues and can be related to a faulty storage capacitor in the main circuit. If this has reduced in value then the + B will be low and so the SWITCH mode can be fluctuating thereby producing the low voltage effect.Please check the secondary + B and confirm the SMPS.
10/17/2011 9:10:56 AM • GE 31GT659 31"... • Answered on Oct 17, 2011
I have a GE model # 31GT659 and no remote. TV
Ge is the most common universal remot make in the world, they make most all the universal remotes for everyone. Go to Walmart and get on for 10 buck or less and you will be back in business. With no channel buttons working this is your only choice.
7/18/2011 1:33:35 AM • GE 31GT659 31"... • Answered on Jul 18, 2011
0answers
I have a Wii. I have connected the video wires to
Welcome to fixya
I have a solution for this
Content
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most TVs or VRCs. First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well. If you are unable to find a set of yellow, red, and white AV inputs on the back of your TV, try looking on the sides, top, and bottom of the TV. Look for any hidden panels or doors as well. Connecting to a Television Audio/Video (AV) inputs are typically located on the back of the TV, but occassionally are on the sides, top, or bottom. Look for inputs marked Audio and Video IN. Do NOT connect your system to anything marked OUT. Don't see these inputs on your TV? Click here. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console Insert the DC plug on the Wii AC Adapter cord into the DC Input connector on the back of the Wii console. Insert the AC plug into a 120V AC wall outlet CAUTION: To prevent electric shock, match the wide blade of the plug to the wide slot and insert fully into the outlet. Plug the transformer into the wall outlet. The Sensor Bar can be placed either above or below your TV screen. Decide which option best fits you and click the image below for additional set up help, including mounting the Sensor Bar and proper alignment.
Your pre-solution is located above. More information is available in the comments
My name is Bruce
1/20/2011 3:41:27 PM • GE 31GT659 31"... • Answered on Jan 20, 2011
Toshiba tv stopped working..( cx32h60
Ok.. What is the status of the LED at the front?
6/8/2010 4:41:24 PM • GE 31GT659 31"... • Answered on Jun 08, 2010
Tv use to turn off wile watching now will not turn
I have a magnavox 31' CRT that did that to me. Turns out the power button on the TV gets stuck and so the slightest vibration of somebody walking past (wood floors) would cause it to power on or off. It would also keep the remote control from working until someone tapped the switch to un-stick it. Small problem considering the TV is 18 years old and still looking good.
12/1/2009 12:13:24 AM • GE 31GT659 31"... • Answered on Dec 01, 2009
Power button will not work
No short, more like an open. Not familiar with this exact model but have seen cold-solder joints on similar ones near the power supply. As long as you are comfortable working around serious potential voltages and are capable with a soldering iron you should be able to find it. Otherwise call a repair shop.
12/1/2009 12:09:57 AM • GE 31GT659 31"... • Answered on Dec 01, 2009
3answers
Getting to s video
You can also press 00 on the remote
6/28/2009 5:52:53 PM • GE 31GT659 31"... • Answered on Jun 28, 2009
TV searchs for channels everytime it is powered on
the only thing i see is getting a UPS and plug tv into it. manufactures dont put batteries in tv's because most people dont unplug their tv.
using a UPS to maintain memory and plugging UPS to keep UPS battery at peak charge
6/28/2009 5:48:24 PM • GE 31GT659 31"... • Answered on Jun 28, 2009
2answers
GE TV 31GT659 - is it Digital?
No, it's not digital. If she has cable service, however, it won't be a problem, come February 2009 as cable services are supposed to supply the ability to "convert."
5/20/2009 7:34:39 PM • GE 31GT659 31"... • Answered on May 20, 2009
GE 31
check electrolitc capacitors in horizontal circuit
11/9/2008 5:41:09 PM • GE 31GT659 31"... • Answered on Nov 09, 2008
2answers
Cannot locate an input selector to change from cable to a recorder
Try selecting channel 00 enter on remote.....I am assuming
you are missing the original GE remote that has an input button
on it ............? Let me know.........T.
10/17/2008 9:55:47 PM • GE 31GT659 31"... • Answered on Oct 17, 2008
I need to know how to access the verticle hold to adjust TV
what do you mean that the picture streched out.this is a strange problem.as vertical problem does not strech it either have a line inthe middle of the raster, shrink both at the top and bottom of raster,lines run up and down on the raster.kindly explain your problem in detail then i will be able to help you.
10/2/2008 6:35:10 PM • GE 31GT659 31"... • Answered on Oct 02, 2008
Dark t.v. screen
press the menu button 3 times then the chanel down 2 times then hold the volume up button
3/17/2008 8:08:24 PM • GE 31GT659 31"... • Answered on Mar 17, 2008
Televison & Video Logo
29 questions posted
Top GE Televison & Video Experts
ExpressFiX
ExpressFiX
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • GE Televison & Video
Most Popular Question
cannot locate input selector change from
  • Televison & Video
