20 Most Recent
GE 25GT511 25" TV Questions & Answers
Don't have remote can't change channel to 03
My solution: Buy a universal remote. You can get them at most electronic stores. After finding brand code in booket(usually included with new remote),enter the code then presto!
Need to replace the coaxial cable connector
This can be pretty tricky. You have to get the new connector pretty hot in order for the solder to flow properly and get a good connection. Also, where the center connector goes inside of the tuner be carefull not to damage anything in that area. Unless you are really good with a soldering iron it may be best to leave this to a repair shop. Thanks
Blurry screen GE 25GT511
hi
There shouldnt be much in the focus system to go wrong as really there is nly the tube base and the flyback transformer. The usual for a TV is the tube faulty so its beyond repair. You could try the focus control, this will be on the flyback transformer. Back off TV, look for a heavy lead going to the dome of the tube at centre top and with eyes ONLY follow that back to the flyback transformer. On the side of that transformer is 2 screws, one near the top is the focus control. You will need a screwdriver to turn it and it usually has a seal to be broken. That will turn from say 8 o clock to 4 o clock no more, turn it up clockwise, try both ways. if it almost fixes but not quite it would be the tube.
good luck
GE 25GT511
Look for where to turn off subtitling. It'll be there somewhere, accessible via the remote.
TV doesn't receive higher channels
Depending on the chassis, it could be the OBT has a bad componet or a parts bad in it or if theres a standup tuner it has to be replaced. You should take the set into a repair place for an estimate good Luck
Taping a show
as it is not seen from outside & can not be seen so it is not there.
no there no hidden compartments
now what you can do for recording is you can connect separate adaptor from market it can be connected from out side.
Missing speaker?
You have a TV with mono sound, and those sets only have one speaker. The same cabinet is used for the sets with stereo sound, which is why there are spaces for both speakers. Your set does not have a second audio amplifier to connect another speaker to.
TV clicks but no sound or picture
if this is a crt it is most likely not worth the repair specially considering the size of the set. Most parts for them cost more then the tv itself sorry for the bad news if its not a crt then thats a different story
GE Model #25GT511 Power on, no picture or sound
The question I have is if the tv stays on but with no pix or sound,we have a way to check,if you place your forearm in the face of the picture tube and the hair in your arm stands up it means you have the high voltage needed to light up the tube but something else is missing like the screen voltage or it has a loose conection in the crt board,if the hair in your arm does not react to static then we are missing the high voltage and the problem might be more involved and related to the horizontal circuit not creating the high voltage needed.If you are familiar with tv service you have a few places to check but if you are not to familiar play it safe and call for assistance from a professional servicer.Let Us know how it goes please.
Trying to find model number on my GE universal remote so that I can get codes for my converter box
Locating the model number on a GE universal remote can vary depending on the specific model. Here are some general tips to help you find the model number:
- Check the Battery Compartment:
- Open the battery compartment on the back of the remote.
- Look for a sticker or label inside the compartment that may contain the model number.
- On the Remote's Front or Back:
- Check the front and back of the remote for any labels or markings that might indicate the model number.
- User Manual or Packaging:
- If you have the user manual or the original packaging, check there. The model number is often mentioned on these documents.
- Behind the Battery Cover:
- Remove the battery cover and inspect the area behind it for any labels or markings that include the model number.
- On the Remote's Body:
- Inspect the body of the remote itself. Some models may have the model number printed on the front or sides.
Once you locate the model number, you can then proceed to find the correct codes for your converter box. The codes are usually included in the remote's manual or can be found on the manufacturer's website. If you are unable to find the model number or the manual, you may need to contact GE customer support for assistance.
If you provide more details about your GE universal remote, I might be able to offer more specific guidance.
Need universal remote codes for sansui hdlcdvd265b
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
4 Digit Universal Remote Codes for Sansui TV ; 0394, 5871, 1052 1556, 1208, 0135 ; 0888, 0310, 6071 ; 6061, 0806, 5441 ; 2832, 0264, 1230.
Replacement Remote Control for SANSUI HDLCDVD265 ...
Amazon.com
https://www.amazon.com > Replacement-HDLCDVD2...
This is a custom built replacement remote made by Redi Remote for the SANSUI remote control number 076R0LJ020. *This is NOT an original remote control.
Rating: 4.4 · 12 reviews ·
US$34.95
Replacement Remote for SANSUI HDLCDVD265, ...
Amazon.com
Replacement remote control for Sansui HDLCDVD265, HDLCDVD325B, 076R0LJ020 with
all functions of original one. It replace each button of original remote ...
US$16.00
Need codes FOR GE UNIVERSAL RC 24914-D TO CONNECT MY roku express
Yes, you can use a GE Universal Remote RC24914-D to set up your Roku Express box. To do this, you'll need to find the correct code for your Roku Express device and program it into the remote. Here's how:
- Turn on your Roku Express device.
- Locate the "Code Search" button on your GE Universal Remote. This button is usually labeled "Code Search" or "Setup."
- Press and hold the "Code Search" button until the indicator light turns on.
- Enter the code 9-9-1. The indicator light will blink twice.
- Point the remote at your Roku Express device and press the "Power" button. If the device turns off, you have found the correct code. If it does not turn off, repeat steps 3 to 5 with a different code until you find the correct one.
- Once you have found the correct code, press the "Code Search" button again to save the code.
The codes for the GE Universal Remote RC24914-D can vary depending on the version, so it's possible that the code 9-9-1 may not work for your device. If that's the case, you can try other codes listed in the remote manual or on the GE website.
I hope this helps you set up your Roku Express device using your GE Universal Remote.
