20 Most Recent
GE 19GT317 19" TV Questions & Answers
Why do I have no picture or sound?
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Do asearch by type in the brand name of your device at its search box.
GE 19GT317 does not power
There is the possibility that; (1) the horizontal output Transistor has shorted out. (2) the horizontal driver transistor and last but not least (3) the H output transformer.
If you have a Isolation variable power supply meter, connect the tv set to the meter. Slowly raise the voltage to 70 to 90 volts ac, but, keep an eye on the amp meter. If the amp meter rises sharply to mid poit while adjusting the meter to 70 volts..stop...you have a "dead short". The set needs trouble shooting and the short(s) eliminated to solve your problem.
If you manage to raise the voltage to 70, turn the set on and raise the voltage to 90 vac. The set should come on, but, the pic will not be that great. This will tell you that you either have a problem with the H driver, a cap, or the H transformer.
Can not get my remote to work, don't know the
hello
You just try one amoung the following four digit codes. Proceedings are given. If one code does not work , try the other one, but after switching Off your TV by mains, and swich it on after some times, say 30 seconds of more. Only these much codes are available with me at this time.
[ 0031 0107 0164 0004 0009 0044 0054 0000 0342 0003 0125 0015 0022 0052 0087 ]
Proceedings
- Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
- Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
- With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
____________________________________________________________________________________
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
- Manually turn on the device (TV, VCR, etc.) to be controlled.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
- Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
- Press and release MUTE to install the code. The indicator light goes off.
Cant get any channels between 34-98
If your remote does not have a menue to access auto channel programing, look for it on the TV itself. It may be hiding behind a small panel door, usually toward the bottom of the tv.Once you find it you may have to figure out how to bring the screen up that has programing feature. The screens usually can be brought up by channel or volume controls. Once the auto programing feature appears you push or press ok. If that does not work you should be able to manually key in each channel, one at a time. There as many variations as tvs. Hope this helps. Good luck. Larry
TV locked on channel 3 and have no remote
Thats EXACTLY what happened to our tv!
Ours was originally locked on channel 4 but I left it unplugged overnight and now its oddly stuck on channel 3.
The only thing I can think of to do is try to search for/buy a remote that will work on the tv to bring the menu up again. I don't know how to manually reset it or do anything.
Menu will not come up. Channel will not change. No remote.
brendee89,
I did not get who the manufacture was of the tv but you may want to see if one or more of
the menue buttons are stuck down on the tv's front panel. This has been a common cause of
problems with Mitsubishi and Sony tv's. It could also cause volume to go up by it's self, no menue
functions, no power up and or no remote control functions to work.
Hope this helps,
Skyman
Need to have tv on chan. 73, for dish access
When I had Dish hooked up I had to use chanel 3 on my television or the video inputs. The Dish box will take care of all the stations that yor receive. You shouldn't have to change chanels with your tv.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Parental Control Locked
for an unknown passwrod try, go to parental control in menu then push mute,pisplay,clear,reset buttons in sequence. you may need to borrow a friends remote to do this. once in you can change your setting.
good luck
