20 Most Recent GE GTD120 System Questions & Answers
5.1 Surround Sound Cutting Out
HI,
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
9/24/2014 2:29:25 PM • GE GTD120 System • Answered on Sep 24, 2014
Turning on surround
push the DSP button it is right above the equalizer.
7/30/2014 6:45:27 PM • GE GTD120 System • Answered on Jul 30, 2014
Getting to fuse
What kind of mixer are you working with?/
7/10/2014 8:53:48 PM • GE GTD120 System • Answered on Jul 10, 2014
Ge universal remote codes for phillips blu ray 3d
GE universal remote control have no set-up codes to any Blu-ray player. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. http://electrohelponline.blogspot.com/ Try this link too http://remotesearch.blogspot.com/
4/20/2014 5:58:06 AM • GE GTD120 System • Answered on Apr 20, 2014
0answers
Remote codes
Be the first to answer 12/13/2013 3:48:26 AM • GE GTD120 System • Posted on Dec 13, 2013Be the first to answer
manual
I trying to hook up
What you have hooked up(y,pb,pr) is component video which carries the video. The sound is trnasmitted through a different cable, RCA(white and red) probably in your case. You need to make sure taht your component connections are in all the way and are making contact and, taht all three are in the correct inputs on the flat screen. It is easy to confuse the colors and all the connections are close together making it easy to make a mistake, I've done it myself. Once you have established your connections are correct, make sure you go through your TV's menu to make sure you are the right menu screen(TV,DVD, etc.)
6/14/2011 12:44:09 PM • GE GTD120 System • Answered on Jun 14, 2011
Forgot the parental code how do we reset
Hello
Just unlock its Parential contol and reset the TV. NB: You must have its original remote control handset to proceed. If you haven't it with you, just boroww it from somone you know, who have the same model number of Tv; just to unlock it. After unlock, you can use universal remote or so.Proceedings are:
Most GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won
6/2/2011 5:31:53 AM • GE GTD120 System • Answered on Jun 02, 2011
Surround sound problems.
Dolby 5.1 is not supported via either of the Aux inputs. Be sure to check your main menu/audio setup screen to ensure that "stereo" is not selected. If it is, DVD's will not downmix, giving you only 2.1 stereo.
2/1/2011 11:30:09 PM • GE GTD120 System • Answered on Feb 01, 2011
I have had a GE
In the system there is a reading eye.Which reads the discs which you insert.This eye is called "lens".If this lens gets weak or dusty then it will not read the disc .As a result it will stop the disc in between and freeze or vice versa.In this case the lens needs to be cleaned and checked.For that the dvd unit needs to be disassembled and checked.But if lens is clean inside then its a weak lens issue ,its by age of the unit.In that case it has to be replaced.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
9/25/2010 6:28:16 PM • GE GTD120 System • Answered on Sep 25, 2010
I dont have remote control
http://www.remotes.com/?gclid=CMLnt-W-h6ICFRRjnAodzyoDVQ
Although, I have never used this site before. They sure "sound" like they deal in remotes though.
6/4/2010 10:35:49 PM • GE GTD120 System • Answered on Jun 04, 2010
Dvd door will not open
My only suggestion is to press and hold the eject button for a period of time (15-30 seconds).
5/16/2010 3:49:23 AM • GE GTD120 System • Answered on May 16, 2010
I got a new sony high Def TV Hooked it up and now
Return it to the store. Once set, you cannot reset the region unless you search far and wide for the hack to reset. The hack usually requires you to push a series of buttons on the front panel to pick new region.
3/15/2010 2:02:13 AM • GE GTD120 System • Answered on Mar 15, 2010
How too connect dvd (GE)GTD 120 player to older sanyo tv
how do you find the parental control code if it was forgotten?
2/26/2010 6:16:04 AM • GE GTD120 System • Answered on Feb 26, 2010
GE GTD120 System Logo
47 questions posted
Top GE Audio Players & Recorders Experts
Rob Hill
Rob Hill
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
