20 Most Recent GPX RDT4004SP AM/FM Radio Questions & Answers
How to set presets gpx rdt4004sp
You can store up to 10 channels. For channels 1-5:: Go to station you desire. Press MEM button. Press 1 button to store. Press MEM button again. Do the same for buttons 2,3,4,5 to store channels. After you store to buttons 1,2,3,4,5 then: For channels 6-10: Go to station you desire. Press MEM button. Press +5 button. Press 1 button to store. Press MEM button again. Do the same for buttons 2,3,4,5 to store channels.
4/25/2013 2:10:37 AM • GPX RDT4004SP... • Answered on Apr 25, 2013
Bad reception fm radio signal
usually batteries...am takes less juice.....battery strength will affect fm signal strength
11/8/2009 6:41:20 PM • GPX RDT4004SP... • Answered on Nov 08, 2009
My screen print font is
1) Press the START button (usually located at bottom left corner of computer screen).
2) Select the SETTINGS item.
3) Select the CONTROL PANEL.
4) Double click the DISPLAY icon.
5) Select the SETTINGS tab.
6) Change the setting in the FONT SIZE to the normal size called . If you don't see FONT SIZE, then click on ADVANCED OPTIONS.
7) Click the OK button.
10/10/2009 1:53:33 PM • GPX RDT4004SP... • Answered on Oct 10, 2009
Instruction print is too small to read and can not turn radio on
Try scanning the instructions you do have into a computer and, then, use the magnification feature in the program that the scanned image is in to enlarge the print.
2/7/2009 8:40:19 PM • GPX RDT4004SP... • Answered on Feb 07, 2009
2answers
Setting the stations on memory
OK HERE'S WHAT YOU DO
1. USING THE UP AND DOWN TUNING, TUNE IN THE STATION
2. PRESS THE MEM SWITCH (LEFT SIDE OF ROUND SWITCH)
3. PRESS STATION LOCATION
4. PRESS MEM AGAIN ---- THAT'S IT
SUMMARY: TUNE, MEM, SET STATION, MEM
9/18/2008 1:29:30 AM • GPX RDT4004SP... • Answered on Sep 18, 2008
Major design flaw
Yep, I had to dig out a swiss army type tool. If you have a glasses repair kit, that might work too.
8/31/2008 3:03:44 AM • GPX RDT4004SP... • Answered on Aug 31, 2008
What watt speakers on GPX C1600 karaoke machine
I would say that as the output is 50Watts music power, a 50Watt speaker would be ideal.
12/26/2023 5:49:04 PM • GPX Audio... • Answered on Dec 26, 2023
GPX SP-60, 5.1 Home Theater Speaker System. I need an owner's manual for it please?
Unfortunately not available anywhere. There are too many items with parts of GPX and SP-60 in them. https://www.google.com/search?q=GPX+SP-60+manual ..
10/4/2023 3:17:24 AM • GPX Audio... • Answered on Oct 04, 2023
How to play cd in gpx cd clock radio crcd 6306 dt
How do I play a CD?
  • Make sure the clock radio is powered on. Once a CD is inserted, playback should start automatically. It may take up to 10 to 15 seconds before CD plays.
9/24/2023 2:16:05 PM • GPX Audio... • Answered on Sep 24, 2023
I own a GPX HM3817DT that does not work. There is no voltage coming out of the transformer. It could be a bad switch or transformer. How can I test either.
Hi 1st check there is voltage going into the transformer, if there is nothing coming out then the transformer is no goodIf there is no voltage going into transformer then check the fuse at the plug
3/31/2023 5:03:11 PM • GPX Audio... • Answered on Mar 31, 2023
My gpx mw240s says error and i cannot play any music. What else should i try doing?
If your GPX MW240S MP3 player is displaying an error message and not playing any music, there are a few things you can try to fix the issue:
  1. Reset the player: Sometimes resetting the MP3 player can fix the error. To reset the GPX MW240S, press and hold the power button for 10 seconds, release the button, and then turn the player back on.
  2. Check the music files: Ensure that the music files you are trying to play are in a compatible format with the GPX MW240S. The player supports MP3 and WMA formats, and if your files are in a different format, they will not play. You can convert the files using a free online converter.
  3. Update the firmware: If the player's firmware is outdated, it may cause errors while playing music. You can update the firmware by downloading the latest version from the GPX website and following the instructions.
  4. Check the storage space: If the MP3 player's memory is full, it may cause errors. Delete some files from the player to free up space.
If none of these solutions work, there may be a hardware issue with the player, and it may need to be repaired or replaced.
2/26/2023 2:26:50 PM • GPX Audio... • Answered on Feb 26, 2023
On my gpx cd home music system HM38170T the cd door won't open. How do I fix it?
If the CD door on your GPX CD home music system HM38170T won't open, here are a few steps you can take to troubleshoot the issue:
  1. Check for obstructions: Make sure there is nothing blocking the CD door or the area around it. Sometimes small objects or debris can get stuck and prevent the door from opening. If you see any obstructions, carefully remove them.
  2. Power cycle the system: Turn off the system and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. Sometimes power cycling can help reset the system and fix any issues.
2/19/2023 10:00:38 PM • GPX Audio... • Answered on Feb 19, 2023
2answers
Downloading songs from itunes to the MP3 player
The GPX mp3 player is incompatible with iTunes (as are most non-iPod mp3 players). There are a few mp3 players out there that are iTunes compatible, but this is not the one.
-Tha Mp3 Doctor
11/18/2022 3:15:32 AM • GPX Audio... • Answered on Nov 18, 2022
3answers
Where can i go for free music for my gpx mw151p 4gb
i wouldn't recommend doing so (piracy is a crime) but there are some free services out there to get music just becareful of what you download from the internet
3/12/2022 11:10:03 AM • GPX Audio... • Answered on Mar 12, 2022
Brand new GPX mp3 player will not pair or show up on usb drive
Instruct the computer to search for it. The computer should automatically find it and load drivers, but it should show in Windows Explorer as a volume in the left pane. Where are you looking? It will only pair with a computer if the computer has Bluetooth and most don't. Pair with a smartphone. How do I transfer my music to my device? This device is capable of playing MP3 and WMA (4ithout DRM) files. To load files requires a computer with a USB connection and the minimum requirements of Windows XP .
  • Connect the player to the USB cable provided in packaging, and then connect the other end to your computers USB port.
  • Once connection has been made between the device and your computer, a "GPX" drive will appear in the computer directory.
  • Double click on the GPX drive
  • Drag and drop your MP3 files and folders into the Music or playlist folder
https://gpx.com/on-the-go/gpx-bluetooth-mp3-player-mwb308r.html ..
3/6/2022 8:42:20 PM • GPX Audio... • Answered on Mar 06, 2022
My gpx mw3837 isnt turning on?
RETURN IT TO PLACE PURCHASED AS DEFECTIVE .
1/7/2022 1:56:14 AM • GPX Audio... • Answered on Jan 07, 2022
I need the manual for GPX Model KCCD3004DP
There isn't one for that particular model https://www.google.com/search?q=gpx+model+kccd3004dp+manual ..
11/19/2021 8:28:37 PM • GPX Audio... • Answered on Nov 19, 2021
NEED Instructions or Manual for GPX Model HTMU3234....
Contact GPX or its distributor to determine availability and source.
9/6/2021 4:30:41 AM • GPX Audio... • Answered on Sep 06, 2021
2answers
Every time i try to
Many online music stores employ DRM to restrict usage of music purchased and downloaded online. The best way to overcome this is to download DRM- free tracks. Some online music stores such as amazon, eMusic and Beatport give you DRM free tracks. Try getting your music from them. Or else you can rip the Cds to get the tracks.
hope this solves your problem.
FixYa!!
4/9/2020 9:31:14 AM • GPX Audio... • Answered on Apr 09, 2020
GPX RDT4004SP AM/FM Radio Logo
9 questions posted
Popular Products
Top GPX Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Grubhead
Grubhead
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • GPX Audio Players & Recorders
Most Popular Question
bad reception fm radio signal
  • Audio Players & Recorders
